Which Auto Trans ?
Im looking on picking up an Teg for a drag car project. Now which auto trans should i hunt down and what torque converter should i pair it up with ? Im looking for the best combo for the track and something that wont blow up on me before 6 months.
Thx,
Ryan
Thx,
Ryan
Right now I don't know of any Honda tranny that can take that abuse. Even built, a b-series auto wouldn't last 6 months of hard racing with a car of decent power.
i am building a auto trans drag car also. I am using the RO trans out of the 90-93 integra. If you are using a b series motor try a later auto trans s4xa out of a 96 on teg. I think the clutches are slightly larger.
i believe there are people producing adapter plates, so that you can run a GM automatic trans in your honda. also the engine will be rotating the opposite ditection, so you will need a custom ground cam as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic »</TD></TR><TR><TD CLASS="quote">i believe there are people producing adapter plates, so that you can run a GM automatic trans in your honda. also the engine will be rotating the opposite ditection, so you will need a custom ground cam as well.</TD></TR></TABLE>
Its a 1000 times more work then that
AnitRiceSuperStar
Mar 22, 2004 11:05 AM
