April FS Sticky please read rules
Old 04-01-2009, 03:02 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default April FS Sticky please read rules
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for Race
Car parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
__________________
boostedcivicsir is offline
Old 04-01-2009, 03:16 PM
WillieWillieFast's Avatar
Default Re: April FS Sticky please read rules
Prices do not include shipping or Paypal charges unless otherwise stated. I might consider some trades, just let me know what you have to offer. More pictures upon request.
Up for sale is my 88 Honda CRX SI rolling shell clean title. Car has been family owned. This car is a head turner. Gets compliments everywhere it goes. Very few clean CRX’S left. Car has gone 10.6 @141 in the qrt. mile. My accomplishments: In 2004 at Import motion Best CRX award , BOTI Seattle 2nd place in S/C, NHRA Pomona 2nd place in SFWD. In 2005, BOTI Seattle 2nd place in S/C, NHRA Pomona semi finals in SFWD. In 2006 NHRA Pomona semi finals in SFWD. What’s all included: NHRA certified chromoly cage(this alone would cost you $1500-$2000), Moroso battery box, battery shut off switch, jdm type-r cluster, driver Sparco bucket seat, fake spoon steering wheel, Type R floor mats, Black with red stitching shift boot and e-brake boot, sump fuel tank with one -12 line 3ft long off the sump, one -10 line 2ft connected to a Magnaflow splitter with two -8 lines ran to the engine bay also one -8 return line, front extended wheel studs, stainless steel brake lines all around, Tilton master cylinder (car has been converted to hydraulic, meaning no more crappy cable tranny problems), also Tilton slipper valve, wings west body kit and fiber image hood with a little damage on it. Car is street legal, all headlight and turns signals work. Would not take much to have a nice Street Comp car. $3300.00 OBO
CLICK ON PICTURES TO ENHANCE IMAGE
Here is some pictures of when the car was running.
Used Motec M4 with, data logging, lambda, and advanced functions unlocked. Comes with data cable, baro sensor, Honda B series distributor, o2 sensor and the motec Honda harness. For more info http://www.motec.com.au/m4/m4overview/ $2250.00 OBO
One B series starter's left $50.00 each
One B series half shaft left $75.00
I made 500hp on 17lbs with a 81m block. This kit is capable of making 800hp + with high boost. Everything has less then 2000 miles on them and less then 8 times at the track. Kit includes: Inline pro T4 manifold with a Tial V60 (1 bar spring) with dump tube, Burg Warner S372 turbo (72m) with 4in down pipe and -10 oil return line and -4 feed line $2000.00
Magnaflow Regulator $130.00 SHIPPED
Gator 300M axles for Honda B series motor.$800.00 SHIPPED
WillieWillieFast is offline
Old 04-01-2009, 03:57 PM
JamaicanDave's Avatar
EK style(96-00) MB products 1pc frontend and mounting hardware
$500 plus Shipping and paypal fees
JamaicanDave is offline
Old 04-01-2009, 05:48 PM
Harry S's Avatar
Del Sohn Racings 8 second Hot Rod Del Sol
$29,500.00
This car is turn key and ready to race!
Engine:
ERL Performance built GSR short block 2.0l with 5 journal ERL Girdle
Darton Sleeves
Manley Turbo Rods
JE Pistons with coatings
Carbon coated bearings
M2 Ported Cylinder Head
Cometic MLS Head Gasket
Ferrea complete Valvetrain
Ferrea Roller Rockers
Crane custom designed cams
Edlebrock adjustable cam gears
Type R valve cover with custom vents for Z10 motorsports evacuation system
Edlebrock Victor X custom Intake Manifold
90mm accu Fab polished race Throttle Body
Custom water/air Intercooler with 4" piping from turbo to throttle body
Edlebrock fuel rails
Eight 1000cc Fuel Injectors
Weldon Fuel Pump
Aeromotive Fuel pressure regulator
Full Race custom exhaust Manifold
Inovative T74mm ball bearing turbo
4" exhaust piping
Tial wastegate
Twin Tial Blow off Valves
Accel gen 7 DFI Engine Management
MSD Ignition
MSD Cap and Rotor
Odyssey PC1200 Battery
Custom Griffin aluminum mini radiator
NGK spark plug wires
NGK spark plugs
NGK wide band 02 monitor
Custom Moroso Oil Pan
Z10 wet sump modular oil pump system
Carbon/Kevlar engine Diaper
Toda Timming belt
Custom side mount timing belt tensioner
NOS direct port system (not in use but plumbed and ready to install)
Custom Fuel Cell
Driveline:
G-Force gear set with handcuff
Quaife differential
Golden Eagle scatter shield
Tilton carbon/carbon clutch and flywheel
Tilton Hydraulic Throwout Bearing
G-force/Long H-pattern shifter with pistol grip handle with top button activation.
Drive shaft Shop Axles and Hubs
Chassis:
Franks Custom Chassis parts including,
Front Traction bar system with angle control,fully adjustable
Funny Car Cage and backhalfed with straight axle
Wheelie bars w/wheelie bar net and wheeleze wheels
Strange rear spindle mounts
Strange rear Brakes
QA1 Rear coilover adjustable rear shocks
Skunk 2 adjustable front control arms
Skunk 2 Front drag coilover springs
AGX adjustable front shocks
Bogart Billet star Front wheels
Weld spindle mount rear skinny stars
Mickey Thompson 28x10x15 front slicks
Goodyear rear skinnies
Exterior:
Franks Custom Fiberglass:
Carbon fiber front end
Carbon fiber doors
Carbon fiber trunk
Carbon fiber adjustable rear wing
Percy's Lexan windows
Simpson Parachute
Interior:
Sparco steering wheel with two step/antilag control button
Quick release for steering wheel
Simpson camlock belts
Autometer tach w/shift light
Autometer gauges Boost,temp,volts,NOS pressure
Moroso switch panel
Hydraulic Handbrake and line lock
"Coldfire" Fire supression system
Contact: Harry
hsviper@hotmail.com
717 940-2424
Harry S is offline
Old 04-01-2009, 06:08 PM
Former Vendor
Evans-Tuning.com's Avatar
Brand new Edelbrock 8 injector intake manifold for a b16a/type r cylinder head. Its the standard finish version, not polished. It brand new in the box, comes with all hardware, secondary fuel rail, etc. If you are thinking of running 8 injectors, you need this intake manifold. 400.00 shipped.
AEM EMS 30-1040"U". Brand new in the box, obd-1 AEM EMS. This is the box with the built-in wideband. Makes life really simple for tuning. 950.00 shipped.
AEM 19-1 serial gauge. Brand new in the box, 160.00 shipped.
Prices are firm, not looking for trades. Pm me with any questions you have.
Evans-Tuning.com is offline
ctr-ek's Avatar
a brand new BW s372r with a 1.10 rear asking 1500firm
t4 twin scroll 44mm gated top mount set up for the BW turbo in a eg or ek with a bseries motor asking 1100firm
turbo smart dual boost controller asking 150obo
im located in NJ perfer pick up but will ship at buyers expense + paypal fee SERIOUS buyers ONLY!
call me for fastest response 551-556-1069 ask for Frank NO BLOCKED CALLS!
ctr-ek is offline
Old 04-01-2009, 06:34 PM
josh green's Avatar
Complete head minus valve cover, does include an obd1 vtec dizzy. I am unsure of the year or mileage but its a good unmolested head, I was planning on using it for a built motor but have changed my mind building an engine. vtec solenoid is missing the plug and a cracked sensor shown in pics. Looking to get $450 pretty firm for it and can ship it for cheap. I am located in northwest Ga.
josh green is offline
Old 04-01-2009, 08:10 PM
tepid1's Avatar
FS: Brand new Prologger
http://www.prologger.com/
I had it mounted via velcro and had the harness go into a terminal strip. I'll include the terminal strip too.
I'm asking $525, but am open to offers. I'm overseas, but it's currently at home with my woman and it's boxed up and ready to go.
Feel free to pm me with any questions.
tepid1 is offline
Old 04-02-2009, 05:14 AM
slowwhitehatch's Avatar
FS: HASPORT MOTOR MOUNTS for 96-00 civic ek
there BNIB with solid inserts they also come with the rubber inserts
the rubber inserts r from another hasport mounts I had before so they r used.
also i do not have the left bracket some way I lost it or miss placed it.
i'm looking to get 380.00 shipped.
slowwhitehatch is offline
Old 04-02-2009, 12:44 PM
building boost's Avatar
fs: brand new WISECO 84mm 9:1 pistons w/ rings/locks/pins. $450 shipped.
building boost is offline
Old 04-02-2009, 11:22 PM
buck02's Avatar
Sparco Pro 2000 seats $1000+shipping sliders will be included for free
PRICE DROP 1000.000 = Shipping
buck02 is offline
Old 04-03-2009, 01:15 PM
FRernesto's Avatar
Inline Pro Manifold for sale. The Manifold has been ported out for a T4 turbo. 350.00
BRAND NEW GRP aluminum rods for sale for 84mm bore. For LS/ B20 motor. 400.00
1995 GSR head stock! All caps, cams, cam gears included. All is stock out of a GSR. 350.00
Used 65mm Edelbrock throttle body 170.00
FRernesto is offline
Old 04-03-2009, 01:39 PM
bracket 4 life's Avatar
JoJo callos racing CRX front end only mucked up for fitment which was very good. $600
FAST ecu and data logger w/ o2 sensor. I have all the plugs for this $650 shipped
Garret GT40r used turbo has some nics on the fins nothing drastic. $900 shipped
IT IS DIVIDED
OBD-2 distributer w/ msd cap and HVC 2 coil in very good condition MAKE OFFER
MSD DIGITAL 7 program in good condition have all the plugs MAKE OFFER
bracket 4 life is offline
Old 04-03-2009, 04:44 PM
Desir Performance's Avatar
kens custom stright axel with gold weld racing spindel mont skinnys, bran new make offer
Full race Hotrod style t4 twin gate divided manifold (turbo face forward) new make offer
Full percy lexan kit with hardware for ek hatch make offer
28x10x15 m&h slicks new make offer
franks fiberglass front end for 92-00 civic make offer
looking for full race t4 divided topmount twingate
42r turbo
etc.....
open to trades lmk what you got
Desir Performance is offline
Old 04-04-2009, 05:39 AM
SFWD tC's Avatar
Selling race car with many extra parts. Asking $9,000-obo for the whole thing.
Chassis-1999 Honda Civic Si Chop Top
Class-All Motor
Engine-B18C1 Stroked and Deck Plate to a 2.3
Bore-86mm
Stroke-98mm
Crank-Eagle B20
Rods-Eagle
Pistons-Arias
Port Job-Port Flow
Cams-Ferrea and Roller Rockers
Valves-Rev
Throttle Body-BDL 74mm
Fuel-Methanol
Tranny-GSR
Header-Custom Burns
ECU-AEM
There are no drag rims or tires with this car. They have been sold all ready. The car is on stock wheels.
I will sell just motor for $5,000.00 with some extras
You can email me at jlopes@twcny.rr.com or on here for info
SFWD tC is offline
Old 04-04-2009, 08:35 AM
alexsracing's Avatar
I am selling my full-race pro am topmount manifold, its t3 flanged with 44mm wastegate flange.
USED
http://www.full-race.com/catalog/pro...oducts_id=1220
Design Features include:
# Optimal downpipe placement for true 4.0 inch diameter piping. Constructed with a low angle taper directly at the turbine outlet, the ideal place for a conical diffuser.
# Optimal turbocharger placement allows use of T3 sized turbines.
# Flanged for single Tial 44mm wastegate only.
# Robotically TIG welded.
# Thick wall stainless steel construction.
# Flange surfaces machined flat for a leak free seal.
Full-race B Series ProAm B Series 3.0 in. to 4.0 in. Downpipe
This downpipe is designed to work ONLY with the Full-Race B-series Topmpunt turbo manifold in a EG, EK or DC chassis.
no vband on the end just open 4"
had to make dent to clear my clutch slave cylinder dosn't affect it.
44mm wastegate dump tube
Tial Silver 44mm wastegate (high pressure) . has 14.5psi spring just missing top hose fitting, I was just running in the lower one and lost the top one
total I paid $2275.00
on the setup with sc61 turbo i had ran 10.8@134 gsr cams 26psi
USED
manifold, dp, wastegate and dumptube combo price $1600.00 shipped
pictures actual product, sc61 is sold
wastegate is missing the top air fitting, but I didn't use it, just the bottom one
some non-vtec stuff was for b20 project fits b18a/b and b20 heads
I have a set of brian crower turbo stage 2 cams new in box never used
part number BC0021
I have a set of brian crower dual valve springs, and retainers, new in box never used
part number BC0020
paid 700 for all new, just open to take pics.
would like to get 650.00 shipped plus paypal 3.5%
alexsracing is offline
Old 04-04-2009, 01:25 PM
DaveF's Avatar
Front mount B series T4(split housing) turbo manifold
- 304 stainless, tig welded by Jm Fabrications
- will not come with wastegate flanges, unless you also purchase my wastegates
- has extra mount for support
- 800.00 + shipping
__________________________________________________ __
Garrett Gt4202R Turbo
- 74mm
-1.10 a/r exhuast housing
- ball bearing
-water cooled
- includes inlet restricter flange
- includes compressor and turbine discharge flange and v band clamps
- does not include air fitting
1500.00 + shipping
Turbosmart progates
- 250.00 each + shipping
- will come with all flanges + clamps
- does not include air fittings
DaveF is offline
Old 04-04-2009, 03:59 PM
94WhtLytng's Avatar
New in box Strange Engineering Honda shocks. Bought for a project and never used. Available with or without 650lb springs. $550 for shocks, $600 with springs + shipping.
94WhtLytng is offline
Old 04-05-2009, 05:53 AM
jasonp's Avatar
I’m Selling this car so I can get into a new home. It makes 820hp and 553tq from T1 Development last August. I have less than 10 full passes on the setup as of August.
SOLD AS A TURNKEY SETUP ONLY
GE Sleeved Block 84mm $900.00
Pistons coated Wiseco Upgraded Wrist Pins $550.00
Manley rods GSR Turbo Tuff $750.00
Z10 Gridle $120.00
Endyn Head Complete Springs Valves and Retainers $1200.00
Skunk2 Pro1 cams $550.00
Edlebrock Intake $325.00
Eriks 74mm TB $175.00
Precision 1600 injectors $325.00
T1 Catch Can $500.00
STR Fuel Rail $100.00
Aeromotive FPR $125.00
Aeromotive Elimator FP $350.00
Full Race Twin Manifold $1200.00
Tial 44mm WG (2) $300.00 each
Tial BOV $200.00
Garrett 4202R Turbo $1500.00
Precision Water To Air Intercooler $650.00
T1 Cam Trigger $325.00
Motec M4 with harness Ignition Expander $2300.00
Fluidamper Crank Pulley $275.00
MFactory Straight Cut 1-4 Gears $3000.00
Richmond Spool
MFactory 4.05 FD
Welded Case
Quarter Master 5.5 Carbon on Carbon Clutch $2000.00
Prologger Wide Band and Boost Controller $500.00
DSS 5.9 Axles and Hubs $1400.00
Spinwerks 15x10 wheels 26x10x15 MT slicks $600.00
Bogarts Rear Skinnies $250.00
Skunk2 Rear Lower Control Arms $150.00
Avid Solid Motor Mounts $300.00
Chassis:93 CX $2800.00
SFWD Setup
Traction Bars
Chromoly Cage with Parachute
Stock Delsol Seat
Seat Belt Harness
All Glass
Total: $24020.00 Willing to sell for $22000.00 OBO.. You can’t find a better Price or Setup for this type of car..
jasonp is offline
Old 04-05-2009, 06:07 AM
connvict's Avatar
ITS 74mm dbb turbo for sale.
Used approx. 4000 miles if that. Comes with all oil and water fittings as pictured.
$1500 shipped anywhere in the lower 48.
Please call or txt (972) 697-8918 for a quicker response as i am not on HT a lot anymore.
located in DFW
Michael
connvict is offline
Old 04-06-2009, 08:38 AM
srt4thatazz's Avatar
Im sellling a few parts i just purchased for the price i paid. Prices do not include shipping or paypal fee.
AEM 30-1040 configured for use with T1 trigger but can easily be returned to stock. $700
Full-Race top mount T4 twin scroll manifold $700
LS crank $100
GSR girdle with main caps and bolts $ make offer
srt4thatazz is offline
Old 04-07-2009, 07:42 AM
vtekthis's Avatar
NLR AMS 1000 boost control-works flawless 700.00 or with c02 setup 800.00
AEM EMS 30-1010 -700.00
B16 JG intake manifold-TB opened up to 70mm ported and polished along with runners. 4injectors 250.00 painted black.
presision 1600 cc injectors-flowed and cleaned by presision beginning of last season 300.00 obo
aeromotive eliminator pump-make offer, used one season
vtekthis is offline
Old 04-07-2009, 07:46 AM
Allan DP's Avatar
stock 05 type S head asking $600
Allan DP is offline
Old 04-07-2009, 10:32 AM
h22crxpwr's Avatar
For Sale H22 Sleeved All Motor Race Block. All New Parts. $2300 +shipping.
Sleeved RS Machines 90mm bore block.
custom short 90mm Arias Pistons with rings and buttons (coated)
Custom Howards Aluminum long Rods
Custom 98+mm Stroker Crank
Comes with All new OEM honda rod and main bearings.
This block is unassembled. Can be assembled for a nominal fee.
$2300 +shipping
h22crxpwr is offline
Old 04-07-2009, 02:15 PM
SynTeg's Avatar
FS: NLR AMS-1000 Boost Controller
BRAND NEW in box. $775 + Shipping
****UPDATE Will sell for $750 shipped if you buy it today only (07APR2009)****
Save a little money since these go new for around 850 Retail.
SynTeg is offline
Quick Reply: April FS Sticky please read rules
