Anyone ever used the Fuel Injector Clinic 2150cc
Old 08-09-2011, 06:38 AM
dantamparacer's Avatar
Default Anyone ever used the Fuel Injector Clinic 2150cc
Im not sure which injectors to get I am stuck between the ID2000's and the FIC2150cc's any have experience with both? I am looking to make between 750-850whp
Old 08-09-2011, 06:47 AM
90blackcrx's Avatar
Default Re: Anyone ever used the Fuel Injector Clinic 2150cc
I have experience with ID injectors and love them to death, no reason to switch up or think differently .
Old 08-09-2011, 06:55 AM
turbo-2nr's Avatar
ID's are in a class of there own
Old 08-09-2011, 06:58 AM
Im looking at running e85 and want to make that power goal, I know the ID2000 will make the lower end but do they flow enough to make 850?
Old 08-09-2011, 07:00 AM
YZFR6's Avatar
We use ID2000's and soon another set of ID1000's on our race car. However I am curious is too what the difference is, I know the DP Performnace guys are running them. I'm sure Tony will chim in... Isn't the FIC a denso injector? Or?
Old 08-09-2011, 07:10 AM
riceburner700's Avatar
the id2000s can go up farther if you have an adjustable regulator so it shouldnt be a problem making 850 on e85
Old 08-09-2011, 07:14 AM
THANK YOU, I was not sure
Old 08-09-2011, 07:29 AM
YZFR6's Avatar
Correct me if I'm wrong but I think bumping the base pressure on any injector will can make it flow more?
Old 08-09-2011, 08:44 AM
turbo-2nr's Avatar
they will but IDs are still very controllable at very high fuel pressures
i also beleave the FIC are only flow matched but not pulssewidth or dead timed matched like the IDs so they wont idle or drive "stock" like
from past experiences with big injectors before ID came along cars would run grate WOT but for part throttle they were eather to lean or to rich one increase in fuel would move the AFR from 17.0.1 to 9.0.1 there was no in between unless your on something like motec were you can adjust individual dead times and offsets
Old 08-09-2011, 09:05 AM
1320ms's Avatar
We run FIC 2150's in our Supra, love them - its the exact same injector body as the ID2000 - if you have any questions about them PM me
Old 08-09-2011, 09:33 AM
2k.civic.si's Avatar
The ID2000's will make a lot more then 850....ive made 700whp on ID1000's on e85
Old 08-09-2011, 09:40 AM
littlebluecrx's Avatar
do the fic's swell like the id's? if not I think they should be good for a lot of people wanting to run other fuels...
Old 08-09-2011, 09:58 AM
1320ms's Avatar
Like i said, it is -literally- the EXACT same injector, so yes they suffer from the same swelling issues.. but with that said, they are cheaper than the ID's
Matt
Old 08-09-2011, 10:14 AM
sewell94's Avatar
The Fic 2150's are pulsewidth matched.
I've used both the Id2000 and the Fic 2150, both work great, they are the same thing in my eyes. The fic 2150's are the same unmodified bosch injector that Id uses for their id2000.
To the Op, what fuel do you plan on running??
Old 08-09-2011, 12:12 PM
turbo-2nr's Avatar
it dont say that on there site so i wasn't sure
Old 08-09-2011, 05:09 PM
htx_jr.95eg's Avatar
I run there 2150's on my secondaries and work great haven't had one issue. Also just switch my primaries to there 900cc as well. I'm on E though.
Old 08-09-2011, 06:44 PM
I planned on running e85 untill I move then probably c16 if e85 is not avaible in that area
Old 08-10-2011, 02:10 AM
Zer0_SpeedWorks's Avatar
Im on 2150s also. They perform like stock on idle.
Also just like id they swell on fuels with mtbe.
Using mine on pump gas and e85 now.
Old 08-10-2011, 05:38 PM
matt k's Avatar
look into the moran injectors proline uses alot of them with the q16
Old 08-10-2011, 06:48 PM
Bugermass's Avatar
They are the same injector...
Old 08-10-2011, 08:56 PM
Boosted_B_Series's Avatar
I've got a bunch of these bosch injectors, you can modify them just like the newer subaru pencil injectors. That's all I'm saying..
Old 08-11-2011, 05:29 AM
dankeg's Avatar
How do you "modify" the 2000cc injector? hit it with a hammer? or put it in a high tech press?
Old 08-11-2011, 06:45 AM
MR.johnson's Avatar
explain.
im running id2000. love them.
Old 08-11-2011, 07:05 AM
hattech's Avatar
ID2000 can support VP Q16?
Old 08-11-2011, 07:25 AM
dankeg's Avatar
Originally Posted by MR.johnson
explain.
Well both injectors come from Bosch. and both injectors are made in the same plant. ID does not produce this injector. They only difference is they way they claim they flow test the injectors to match them.
Quick Reply: Anyone ever used the Fuel Injector Clinic 2150cc
