Alternator drain????
Old Aug 9, 2002 | 06:51 AM
AussieK24's Avatar
Default Alternator drain????
I was toying with the idea of a switch to disconnect my alternator at WOT. Would this make a damn of difference?? Would my battery be able to supply the car without dropping volts in...oh....say.....14.3 seconds??? People talk about improvements from underdrive pulleys but I wonder if this would work??
Questions, comments, queries, concerns????
Old Aug 9, 2002 | 03:12 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Alternator drain???? (b16a4me)
this will cause more problems that anything. The ECU needs a stable voltage supply. When you cut out the alt, your voltage will drop to about 11.6-12.0 volts.
The lower supply voltage will cause false readings from sensors and other little freaky things.
Old Aug 10, 2002 | 02:21 AM
AussieK24's Avatar
Default Re: Alternator drain???? (Mista Bone)
Cool thanx
fatboy1185
Oct 8, 2010 04:33 PM
blue_hatch
Jul 12, 2007 05:30 PM
Pooby88
15
Dec 19, 2006 07:53 PM
bonta-kun
May 12, 2003 06:08 PM
