Alternator Amperage
I was having voltage problems with everything on-
Fan,water pump, msd, 2- fuel pumps and the rest of
the electronics needed to run a car.
I am using a odyssey pc680 battery.
Upgraded to a 165amp alternator and 2awg cable and it made a hell
of a difference.
of a difference.
my car was running an OBD0 D series alternator, rated at 55 amps.
as rpm went up, voltage would decrease down to ~11v
swapped in an OBD1 alt at 80amps and voltage dropped, but only to ~13.4v
it seemed to help me a lot.
Im looking at getting an aftermarket high amperage alternator. What kind of amperage are some of you guys having success with. Alterstart has a 135 amp for 179 and a 170 amp for 199. To use the 170 amp ill have to change the plug on my harness so just curious. They dont make the 170 amp for obd1 hondas for some reason. But its just a plug change away.
http://storesense1.mysuperpageshosti...ail.bok?no=469
Your fitment would be the 90-93 integra for your obd 1 with the round plug instead of the square one.
I have a 2008 Honda Civic GX. How much does the stock alternator put out? Stock alternator number is: 31100-RNE-A01 (MITSUBISHI) (AHGA75)
I can't find the info any where. Does anyone know? Thanks.
