AEM EPM
#51
Re: AEM EPM
I just tuned a fully built Fox Body Mustang with a 76MM Turbo'd 302 using the AEM and EPM with LSX coils in wasted spark and it was flawless. I think I'll be using the EPM more often whenever possible. It just makes things go so much smoother.
#52
Re: AEM EPM
i am running the aem epm w/kseries coils and just got a call from jeff that the car is up and running and goes on the dyno maybe today but from what he says its already better.
#53
Re: AEM EPM
In for results, I have the EPM now too and I was holding off on buying coils pending your results Jeff told me you were going to be running the LS coils, why did you change?
#56
Re: AEM EPM
Just got an email from jeff and he says the ignition is working great i had 4-5 degrees of timing walk with the msd dizzy and digital 6 and now its only 1-2degrees.the car want on the dyno today and everything worked flawless.Jeff said he had the gm coils and the tsx coils and wasnt share which he wanted to use but decided on the tsx ones because there one piece and wont come apart from changing plugs constantly.He made a custom hold down for them to set on the bseries valve cover.I cant wait to see it when i pick it up.Ive been without my baby for 2weeks now
#57
Re: AEM EPM
^^^ congrads, hopefully they have enough in them to spark off the big boost, certainly beats buying the Pro-14/Pencil Coils which is what I am looking at now.
#59
Re: AEM EPM
We've switched our setup to the full AEM setup (EMS s2, EPM, Ignition, Coils) and should start tuning next week when our new motor arrives. Will let you know how we get on
#66
Re: AEM EPM
we are using the aem twin fire and the pencil coils im running ngk iridium spark plugs 9s .024 gap and i had no problems at all and we trapped 169 alrready.. the only thing im not using its the epm bc i had the t1trigger set up since 2007 but im goin to try in a true street car that im working on now its going to be a full aem set up aem series2 ecu, aem epm, aem pencil coils and twin fire i hope it works just fine...
#74
Re: AEM EPM
im on the t1 trigger with cop, and pro14
i have been waiting for good results with the epm since im on an aem ems as well
advantage to me as far as i know, but i may be wrong is with the epm because its a set and secure deal as to where my trigger magnetic pick up tends to become loose at times.
am i correct in saying the emp gets tightened like a dizzy would with less chance ot coming loose
#75
Re: AEM EPM
My EPM just has one bolt hole that goes to a factory dizzy bolt hole (2 would prob of been better), and you re-use the piece off your OEM dizzy that slides into the cam end to spin it, otherwise there is nothing to adjust.
