adding weight to the front ??
Old Jul 17, 2013 | 01:12 PM
turbo boost's Avatar
Default adding weight to the front ??
hey i see alot of cars with weight bars ....lead in there traction bars...does this help much with 60fts? and if so how much weight is the norm?...like to try new things to lower my 60fts...any input?
Old Jul 17, 2013 | 01:25 PM
blade0314's Avatar
Default Re: adding weight to the front ??
i just bought myselfa nrg tech traction bar and will be putting roughly 100lbs up front.. its best to have weight as low to the ground infront of the tires for traction purposes, it will yield better 60 fts for sure but you have to dial the car in according
Old Jul 18, 2013 | 10:24 AM
ZCHondaCRX91's Avatar
Wouldn't the added weight help traction, but actually slow it down on the big end because of the added weight?
Old Jul 18, 2013 | 10:36 AM
blade0314's Avatar
in street all motor class as well as most classes theres a minimum weight requirement
Old Jul 18, 2013 | 01:49 PM
MrParks's Avatar
the maximum ballast weight is a minimum of 2 bars which can weigh in at 100lb a piece. keep that in mind.
Old Jul 18, 2013 | 04:01 PM
were not in a class or have class rules here..its just all out usually....so the weight is just for traction purposes.....just wanted to see if it would really make a diff on a 600-700 whp car....with the 60-330fts
Old Jul 18, 2013 | 04:02 PM
Twenty47's Avatar
ive seen an all motor car pick up 2 tenths adding 200 lbs. and GAINED mph.
Old Jul 20, 2013 | 08:40 AM
Topdawgg's Avatar
im in the same boat, the weight requirement isnt anything up here, but I wanna put some weight up front to go from a 1.7-1.8 to a 1.6-1.7 60ft
superpilun
Dec 17, 2005 11:52 AM
allmotorhonda
Jan 2, 2003 04:55 PM
Apocalypse
Nov 8, 2002 04:45 AM
