Precision 6766 1.32 t4 divided
Hello, I have precision 6766 turbo 1,32 ar t4 divided in a b18c4 85mm bore with top mount manifold, but with my wastegates fuly closed I can't make more than 40 psi of boost, anybody make more boost on same engine with same turbo? Is journal bearing turbo.
Thanks in advance
Thanks in advance
Re: Precision 6766 1.32 t4 divided
Do you know your Density Altitude? By full closed WGs do you mean you completely unplugged them? Or just turned whatever boost control you have all the way up?
i run 14 psi spring wastegates, and when i say fully closed its because i have 100% closed in duty cycle boost controler in s300. Any advice for make more pressure?
I see, is like this right https://honda-tech.com/forums/drag-racing-36/how-do-i-plumb-wire-dual-mac-valves-boost-control-3151864/
Up here in the damn mile high city we have same issue. 6765 1.32 a/r turbine housing mac solenoid with co2.
Car only makes 35-36 psi max up here. We are using the T1 wastegate sensor so i know the gate is shut all the way. The air up here is just so shitty it maxs out much earlier.
When we go to races where the DA is tons lower (ours is usually 8000+) the car makes 40+psi easy.
Anyway long story short the DA could be douching you...
MatthewMenze
10-23-2013 09:06 PM
