ACT Clutch question
Old Aug 23, 2007 | 11:00 AM
baxter04's Avatar
Default ACT Clutch question
I have a 92 Civic HB with a B-Series Motor fully built. My clutch is brand new-Xtreme Plate with a six puck unsprung disc. My old one was worn out so I had a brand new one installed. I took it to the track and I'm having a problem with my clutch. When I stage, stepping on the clutch all the way down and not letting go of the gas at 7000 rpm, it moves/creeps. I never had a problem before using the same brand. Checked the hydraulics and bled it after the install, everything is within specs. Any input will be greatly appreciated.
Old Aug 23, 2007 | 11:36 AM
h22crxpwr's Avatar
Default Re: ACT Clutch question (baxter04)
have you adjusted the pedal?
Old Aug 23, 2007 | 11:49 AM
baxter04's Avatar
Default Re: ACT Clutch question (h22crxpwr)
Yes.
Old Aug 23, 2007 | 12:06 PM
h22crxpwr's Avatar
bent pressure plate diaphram? happened to me before. pushed clutch all the way in and car still crept forward on its own. take it apart and check it. did you use a new throwout bearing?
Old Aug 23, 2007 | 12:39 PM
A train's Avatar
is your flywheel milled to hell thats a possible issue or is it new?
Old Aug 23, 2007 | 12:41 PM
baxter04's Avatar
Default Re: ACT Clutch question (A train)
It's a brand new act flywheel.
Old Aug 23, 2007 | 12:42 PM
baxter04's Avatar
I bought the whole kit and installed new bearings.
Old Aug 23, 2007 | 12:47 PM
A train's Avatar
sounds to me like a bad plate! is the slave or the master bad!
Smcneal1970
Jun 11, 2018 06:54 AM
str8up720
Transmission & Drivetrain
Jan 22, 2015 10:51 PM
kwah
Jan 31, 2011 08:42 AM
SOHC_MShue
Oct 9, 2008 05:19 PM
mattmw88
Jun 3, 2007 04:52 PM
