96 ls????
Old Aug 18, 2006 | 01:07 PM
LILSOWEK's Avatar
Default 96 ls????
im thinking of going with this set up. but since its the first engine im going to build i wanted to ask u guys first! im thinking b18b bottom block, b18 crank, b18 rods, type r pistons, and gsr head??? im thinking of getting around 12.5:1 comp ratio. or of going with about the same set up but with b20 block, b20 crank & rods! what do you guys think??? will i be able to use 91 octane because i herd that after 12.0:1 ratio i need racing fuel, is that true???? i have a stock ls with 2G's to spend, i want to make it fast, i had recently owned a 97 trans am, i was running high 13s and now with stock ls, i feel super slow, so what do you guyz think i should do???
Old Aug 18, 2006 | 01:25 PM
FTP racing's Avatar
don't think you'll be able to get that comp...with type r pistons!.......b20 block b16 head would be much better....but you'd need to replace pistons...with high comp dome ones.....
Old Aug 18, 2006 | 01:42 PM
LILSOWEK's Avatar
I was taking a look at the je piston i think 12.5:1 and at the wesico 12... :1, but is it possible to run a reliable engine at 12.5:1 comp ratio with 91 octane
Old Aug 18, 2006 | 09:19 PM
BlownHatch's Avatar
Default Re: (LILSOWEK)
I tell you what ,you will not be doing much with 2 grand.
Old Aug 19, 2006 | 10:45 AM
FTP racing's Avatar
Default Re: (BlownHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownHatch &raquo;</TD></TR><TR><TD CLASS="quote">I tell you what ,you will not be doing much with 2 grand.</TD></TR></TABLE>
MANS GOTTA POINT 2K...NOT ENOUGH!
Old Aug 19, 2006 | 02:28 PM
LILSOWEK's Avatar
i got hook ups for some parts, i just dont know about what would be a good compression ratio to use 91 octane and to have a reliable engine
Old Aug 19, 2006 | 04:43 PM
fmfkid250's Avatar
i did not read anywhere that you wanted to stay all motor, it looks like you do...boost is cheaper and more reliable (given you do not push it to much) you can find a "kit" for around 2000 to give you alot of power to break into the 11's on the stock motor...
i ran 12.5:1 motor on 94 octane and it was good you just have to be conservitive..
Old Aug 19, 2006 | 05:06 PM
LILSOWEK's Avatar
i wanted to put a gsr head to get more rpms? so i can at least rev up to 8k
Old Aug 19, 2006 | 05:59 PM
fmfkid250's Avatar
on boost it would not help much
but just to bolt it on to get more power, yes it would run better, to do so you are going to need a good bit of stuff such as oil to the head, new ecu.. and all the gsr top end stuff. Then after all of that it is not safe to rev to 8000 rpm in a short time you will stretch a rod bolt resulting in a spun rod bearing, the gsr crank has a smaller stroke and the rod to stroke ratio is better and the gsr rod bolt are bigger (9mm instead of 8mm(ls)) so if you wanted to do that then spin it to 8k i would recomend arp rod bolts its a must...
(20-30 whp gain)
hope this helps point you in the right direction i dont know this from what people said ive learned the hard way....i started all motor spend 3k then everything broke then went boost and loved it. ask someone local to take you for a ride in there 300whp civic.....
Old Aug 19, 2006 | 06:25 PM
LILSOWEK's Avatar
so what alright turbo can i get for my ls??? for about 2Gs
Old Aug 19, 2006 | 07:46 PM
fmfkid250's Avatar
what kind of car do you have?
Old Aug 19, 2006 | 07:49 PM
fmfkid250's Avatar
http://hondamarketplace.com/zerothread/1726834
http://hondamarketplace.com/zerothread/1673190
Old Aug 19, 2006 | 09:29 PM
LILSOWEK's Avatar
umm i'll think about it!
Old Aug 30, 2006 | 04:58 PM
LILSOWEK's Avatar
so its 11.5 comp ratio to high for turbo???
Old Aug 30, 2006 | 05:25 PM
ninesecrx's Avatar
You can make it happen on 2k. If you did all the work your self...
If it was me, I would buy some CP 12-1 pistons, get some Eagle rods and a set of ACL bearings. Bore the block a half. mil over. Buy a VTEC head and if you have some change left over, at least get your self a set of springs and retainers for your cycl. head.
Old Aug 30, 2006 | 06:22 PM
LILSOWEK's Avatar
ok cause im gettinga b18c1 bottom block bored 81.5mm and it custom rods, and 11.5 comp wiseco pistons, im also getting a rebuilt gsr head! i was thinking of going turbo in the future!
Old Sep 7, 2006 | 08:21 PM
LILSOWEK's Avatar
All_MotorEK
Dec 7, 2008 12:11 PM
Topdawgg
Mar 27, 2007 10:24 AM
LILSOWEK
Aug 19, 2006 06:21 PM
phatsol
Nov 8, 2001 02:35 PM
