6 "point" cage needed for 11.99 and faster, which "points" though?
I am in need of a cage very quickly and the closest 1/4 mile track to me will MAKE SURE i have a cage in the car (which is a good thing)
it says i need a 6 point
now in saying 6 points are they referring to:
-2 from main hoop(obviously)
-2 from back half(obviously)
-2 from where else?
do they mean door bars?
or do they mean 2 diagonal bars from the main hoop to the floor?
i would like to add door bars but i want swing outs, and will not be able to add those in right this minute
any help is great
-2 from where else?
any help is great
Re: 6 "point" cage needed for 11.99 and faster, which "points" though? (mrbsponge)
2 front door bars ,but if your puttin in a 6 point you might as well just go straight for the 10 point.
also any thing below a 10 point is no go if your traping over 135 regardless of et
* B A N N E D *
1 Post
Re: 6 "point" cage needed for 11.99 and faster, which "points" though? (B18C1CYA)
Sing outs are cool for practicality-in a street car, but suck for the whole purpose of the cage- chassis rigidity. weld em and deal (LOL- i didnt like it either)...
Re: (Johnny O A20 KIller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny O A20 KIller »</TD></TR><TR><TD CLASS="quote">It is 11.49 and faster now</TD></TR></TABLE>
you are correct they havent updated thier site yet, this rule changed due to General Motors and fast corvettes coming from the showrooma capable of 11.80s
last track visit was 11.20-11.10s so i know i might accidentally hit a 10second pass
Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">
WHat GM car or corvette came from the showroom capable of 11.80's? I know the new z06 is close, but the rule change came a while ago...
I've personally seen a new c6 Z06 trap 123-125mph. That's good for a mid to low 11..
as far as the cage goes. make the door bars solid. swinging is nice, but like the others are saying. Safety is most important.
-Chad-
-Chad-
Re: (allstokhonda)
you would have 2 points from roll bar, two from roll bar back to struts, and 2 to the front under/near dash
i thought stock vettes are running low 12's
Re: 6 "point" cage needed for 11.99 and faster, which "points" though? (NAPIER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER »</TD></TR><TR><TD CLASS="quote">2 front door bars ,but if your puttin in a 6 point you might as well just go straight for the 10 point.</TD></TR></TABLE>
Yeah that's what I was going to recommend too.
Re: (allstokhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allstokhonda »</TD></TR><TR><TD CLASS="quote">I've personally seen a new c6 Z06 trap 123-125mph. That's good for a mid to low 11..
-Chad-</TD></TR></TABLE>
What did it run? 11.7 was their advertised 1/4 time, but I haven't saw anyone break into the 11's yet...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 »</TD></TR><TR><TD CLASS="quote">where can i look up the rules and see what i need to run at a 1/4 mile track?</TD></TR></TABLE>
http://www.nhrasportcompact.com/2006/rules
Re: (slowteg550)
thanks guys for the help, much appreciated
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowteg550 »</TD></TR><TR><TD CLASS="quote">
WHat GM car or corvette came from the showroom capable of 11.80's? I know the new z06 is close, but the rule change came a while ago...</TD></TR></TABLE>
the NEW vette(06) model was tested and with NO parts added, they were able to run an 11.6, tire pressure was about the only thing they did, i also think they removed the paper airfilter
and
C5 Z06's were capable of running 11's stock. Several new Z06's at the local track have gone in the 11.30-11.50 range on street tires, and one has gone 10.9's on bfg's.
My question for the people are saying that its 11.49 and lower, do you run in NOPI at all? They are still at 11.99.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">also any thing below a 10 point is no go if your traping over 135 regardless of et </TD></TR></TABLE>
haha that's such a shitty rule
Re: 6 "point" cage needed for 11.99 and faster, which "points" though? (ILLICON5000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILLICON5000 »</TD></TR><TR><TD CLASS="quote">
haha that's such a shitty rule </TD></TR></TABLE>
If you are trapping 135 and not running 11.4's you don't really need to be racing
well I was reading the rules and it is kinda unclear , it talks about if you have a stock fire wall and floor pan then you can run just a roll bar , kinda cunfused now ???????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">well I was reading the rules and it is kinda unclear , it talks about if you have a stock fire wall and floor pan then you can run just a roll bar , kinda cunfused now ???????</TD></TR></TABLE>
thats right. if you have a stock firewall, floor and body, rearward of the firewall, you can run a roll bar in place of a full cage if your car runs 10.00-10.99. i don't see any mention of speed in that paragraph therefore speed doesn't matter.
Re: 6 "point" cage needed for 11.99 and faster, which "points" though? (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 »</TD></TR><TR><TD CLASS="quote">
thats right. if you have a stock firewall, floor and body, rearward of the firewall, you can run a roll bar in place of a full cage if your car runs 10.00-10.99. i don't see any mention of speed in that paragraph therefore speed doesn't matter. </TD></TR></TABLE>
but i am pretty sure if you want to run SPFWD, this exception doesnt count.
imprezdcrew
Welding / Fabrication
05-31-2008 09:57 AM
mstewar
08-14-2004 07:38 AM
