13" rim/slick and gsr front brakes??????????????????????
I have a set of 13" rims with slicks and they are catching on the caliper, I have gsr front and rear brakes.
I have read about people using spacers, is this the correct way and if it's okay where can I buy them.
Re: 13" rim/slick and gsr front brakes?????????????????????? (jdmcoop)
depends on how much room you need.
if its just catching by a little bit then 1/4 spacers from autoparts/tire store will be fine, but, if its hitting hard core you may want to hit up bogart and get there 1/2 spacers..
Mr. Badwrench
Re: 13" rim/slick and gsr front brakes?????????????????????? (HYBRID_H@TCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYBRID_H@TCH »</TD></TR><TR><TD CLASS="quote">depends on how much room you need.
if its just catching by a little bit then 1/4 spacers from autoparts/tire store will be fine, but, if its hitting hard core you may want to hit up bogart and get there 1/2 spacers..</TD></TR></TABLE>
as long as you arent trying to put in an inch of back space, with the spacers youll be ok. as said above, if it is just a little bit, .250 spacers are fine.
CRXBart
19
11-05-2006 06:03 AM
