11.20 DelSol h22
#27
Re: 11.20 DelSol h22 (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViC SiR »</TD></TR><TR><TD CLASS="quote">as i said Stock Internals with costum headears, t3to4e turbonetics, smart turbo B/O, hks 38mm w/g, 3" fmic, 70 shots dp & p30 ecu tuned with UBERDATA </TD></TR></TABLE>
so 450whp on a stock h22?
https://honda-tech.com/zerothread?id=1323896 - this thread says u have pistons/rods. maybe its a different h22.
#28
Re: 11.20 DelSol h22 (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1323896 - this thread says u have pistons/rods. maybe its a different h22.</TD></TR></TABLE>
#29
thats my friends lued
#30
Re: 11.20 DelSol h22 (CiViC SiR)
other modifications :
walbro 255 fuel pump.
550 cc
vortec SFMU
centerforce dual kit
fedanza flywheel
3" dp
lunch control at 6500 rpm
550 cc
vortec SFMU
fedanza flywheel
3" dp
#32
Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">hmm what duty cycle are 550's at when making 450whp?</TD></TR></TABLE>
don't forget the fuel jet's too
#37
Re: (Hulk22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulk22 »</TD></TR><TR><TD CLASS="quote">are you running a thicker head gasket to lower your compression and is that 16psi on race gas?</TD></TR></TABLE>
no every thing is stock
but my bearings are damaged
#38
Re: (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">so 550's and a fmu? what's your fuel pressure like and duty cycle and what ratio fmu?</TD></TR></TABLE>
it should be somewhere between 80-90 psi, duty cycle 95% , 5:1
#39
Re: (CiViC SiR)
damn that cool as **** sorry about your bearings, im getting my turbo done in a few weeks and they told me in order to run over 15 and up on pump gas i would need a thicker head gastket, but if i can lay do 350-400 to the wheels with out doing the thicker head gastket, that will get me by until the block can get built.
#43
i don't know about that, and there is some H.T. members that feel the same way.
i think we need to see a video or at least some pics. of the setup.
#45
Re: (Hulk22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulk22 »</TD></TR><TR><TD CLASS="quote">damn that cool as **** sorry about your bearings, im getting my turbo done in a few weeks and they told me in order to run over 15 and up on pump gas i would need a thicker head gastket, but if i can lay do 350-400 to the wheels with out doing the thicker head gastket, that will get me by until the block can get built.</TD></TR></TABLE>
yes u can
i can say only one word "TUNING"
yes u can
#46
Re: (91civicDXdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">what are you using for fuel management? what i mean is, how are you idling 550cc injectors at 80psi with an FMU?</TD></TR></TABLE>
@ idle is not 80 psi its only when it reachs 16psi thats what fmu's for
and UBERDATA to control the 550 injectors
#47
Re: 11.20 DelSol h22 (boostfeen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfeen »</TD></TR><TR><TD CLASS="quote">i don't know about that, and there is some H.T. members that feel the same way.
i think we need to see a video or at least some pics. of the setup. </TD></TR></TABLE>
i didnt believe it too when they gave me the slip after the run i thought i was between 11.80 and 11.60; so i totally understand u, but i will prove it with vid. this week
