10's possible??
Old Oct 15, 2004 | 01:30 PM
ek9turbo's Avatar
Default 10's possible??
can we break the 10 second barrier with 123mph track speed?
here is some pics of the car
Modified by ek9turbo at 3:56 AM 10/18/2004
Old Oct 15, 2004 | 01:38 PM
toolowsol's Avatar
Default Re: 10's possible?? (ek9turbo)
looks like you ran 11's so i would go ahead and tell people your car runs 11's...
Old Oct 15, 2004 | 01:42 PM
silverb18's Avatar
Default Re: 10's possible?? (toolowsol)
I think you mean can you break the 11 second barrier. BTW, I don't think those trap speeds are high enough to get into the 10's. Someone else can chime in though.
Old Oct 15, 2004 | 01:49 PM
SpoolnG2's Avatar
Default Re: 10's possible?? (silverb18)
No, those et's are about right for what your running as your mph. 10s would be more like 127-132 mph
Old Oct 15, 2004 | 01:50 PM
VisualAutoMotoring's Avatar
Default Re: 10's possible?? (SpoolnG2)
very very light car and a hell of a 60 ft time might be possible
A buddy of mine ran 10.78@123 EG chassis H22 drag car
Old Oct 15, 2004 | 02:36 PM
DIRep972's Avatar
Smarter than you
Default Re: 10's possible?? (PRojectSi2)
yeh it is possible, just have to be driven well and set up right.
Old Oct 15, 2004 | 04:29 PM
BEEYOND's Avatar
Hence torque of the H22 matters too.. not only HP!!!!
I've seen cars with good torque numbers run way better times then cars with high PEAK hp. Very true!!!
Old Oct 15, 2004 | 04:30 PM
BEEYOND's Avatar
you are probably getting a 1.6-1.7 60ft. If you are getting 1.8-1.9 60ft, you are probably losing some topend power. So I'd say this will be the very best unless you are REAR DRIVE.... Very nice time though!!!
Old Oct 15, 2004 | 05:23 PM
Ri5e's Avatar
With 400 WHP as in your signature?
B.T.W., how much does your car weigh?
Old Oct 15, 2004 | 10:53 PM
JDMs1eeper's Avatar
I think you can hit 10's
I've seen this guy run, this car is sick. It seemed like he was having launching problems tho i think. Good Luck
(he has a 96-00 style hatch; just helpin ya out ek9turbo)
Old Oct 15, 2004 | 10:59 PM
Boostfed's Avatar
New User
I don;t think it is possible at the weight of an EK hatch, unless you REALLY REALLY hook up with a 1.5 60' time but still the MPH is low for 10's IMO. My buddy Freddy who is also local to us here went 10.75@131mph in his CRX with 440whp though. He now makes 515whp but his Crower exhaust cam snapped. Brian from Millenium went 10.75@136mph in an EG Hatch, Grey from Millenium went 10.92@132mph in a 91 Integra. Shad yours and my tuner went 10.44@144mph in his EG hatch last year, this year his old 99 Si Coupe went 10.9x@140+mph breaking trannies. I went 11.20@132mph, shitty track conditions and slipping clutch. Good luck, your set up is impressive.
Old Oct 15, 2004 | 11:46 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: 10's possible?? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">yeh it is possible, just have to be driven well and set up right. </TD></TR></TABLE>
Old Oct 15, 2004 | 11:53 PM
Adi Radoncic's Avatar
On Fire!
Do you have a time slip from the 11.3 you ran?
Post up the times from that run if you can.
Old Oct 16, 2004 | 06:32 AM
ek9turbo's Avatar
Default Re: 10's possible?? (JDM S1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM S1eeper &raquo;</TD></TR><TR><TD CLASS="quote">I think you can hit 10's
(he has a 96-00 style hatch; just helpin ya out ek9turbo) </TD></TR></TABLE>
thanks
and yes if u saw the car running u can tell we launching and traction problems, still spinning half way throug second
Old Oct 16, 2004 | 06:34 AM
ek9turbo's Avatar
Default Re: 10's possible?? (nicholashang87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicholashang87 &raquo;</TD></TR><TR><TD CLASS="quote">you are probably getting a 1.6-1.7 60ft. If you are getting 1.8-1.9 60ft, you are probably losing some topend power. So I'd say this will be the very best unless you are REAR DRIVE.... Very nice time though!!! </TD></TR></TABLE>
best 60ft is 1.8
Old Oct 16, 2004 | 06:36 AM
ek9turbo's Avatar
Default Re: 10's possible?? (newgsr)
here is the time slip
Old Oct 16, 2004 | 06:41 AM
ek9turbo's Avatar
Default Re: 10's possible?? (TurboSmart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSmart &raquo;</TD></TR><TR><TD CLASS="quote">With 400 WHP as in your signature?
B.T.W., how much does your car weigh?</TD></TR></TABLE>
car wieghs 2340lb with out the roll cage so now may be 2420lb empty weight
Old Oct 16, 2004 | 06:52 AM
Squirtin EGsr
Guest
Posts: n/a
post some pics of the car please
Old Oct 16, 2004 | 07:02 AM
On Fire!
Default Re: 10's possible?? (RiceRocket12s)
Sorry to discourage you but looking at your short times and your slip, with the power and weight your making its gona be reeeeeeeeeeeeeeeeely though to hit a 10.
Are you running a pritty small turbo?
Old Oct 16, 2004 | 07:10 AM
DIRep972's Avatar
Smarter than you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9turbo &raquo;</TD></TR><TR><TD CLASS="quote">here is the time slip
that time slip still has a ton left in it. Get the suspension and slick combo figured out and you should go 1.6's.. If you don't have a scramble hooked up you should hook one up, a 1.6 60' and hitting high boost in 2nd you will probably go 4.6 in the 330'... The rest is just power/gearing and hitting the shifts. It's definitly possible.
Old Oct 16, 2004 | 07:26 AM
DaveF's Avatar
that time slip still has a ton left in it. Get the suspension and slick combo figured out and you should go 1.6's.. If you don't have a scramble hooked up you should hook one up, a 1.6 60' and hitting high boost in 2nd you will probably go 4.6 in the 330'... The rest is just power/gearing and hitting the shifts. It's definitly possible.</TD></TR></TABLE>
this guy knows what he's talking about...
get them short times covered and 10's are all yours.
Old Oct 16, 2004 | 08:05 AM
Boostfed's Avatar
New User
After seeing the timeslip, I am seeing your point Chris! With a low 1.6 60' which will save him .2 in the 1/8 and possibly .3-.4 in the 1/4, 10's are there dude! Sugar Cookie teaching you well!
Old Oct 16, 2004 | 10:43 AM
ek9turbo's Avatar
i ll be doing some suspension udjustments, and run less air pressure, spray the intercooler
we were running 11psi in the tires i know we can take it down to 8-9 psi should make a difference
ill be happy if it runs 10.9999999
thanks for the comments guys
Old Oct 16, 2004 | 11:27 AM
h22 civic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicholashang87 &raquo;</TD></TR><TR><TD CLASS="quote">A buddy of mine ran 10.78@123 EG chassis H22 drag car
yupper
Old Oct 16, 2004 | 01:29 PM
Tyler H's Avatar
I've gone 11.01 @ 124 with a touch over 400 hp in a 2550lb street car. The 60' on that run was a mid 1.7. Decent, but I've done better. Stock JDM H22, 14 psi. There's definitely a bit more ET with the power you're making. On a really good run, you can hit a 10 as the car sits right now (hp wise).
Tyler
