**Post your Fuel System and Questions**
Old 04-28-2009, 09:30 AM
  #51
captamericao9's Avatar
Default Re: **Post your Fuel System and Questions**
I dunno whether or not that was E85 or gasoline actually
Old 04-28-2009, 09:40 AM
  #52
Mr. Badwrench
boostedcivicsir's Avatar
ok guys this isnt a thread about who made what on corn or not.
please back to the topic.
Old 04-28-2009, 11:29 AM
  #53
E85B18's Avatar
Nice set ups guys!
Old 04-28-2009, 01:05 PM
  #54
rudebwoy's Avatar
fullblown dual intank walbro setup
8AN feed, 6AN return, Aeromotive fpr , edelbrock rail, precision 1600cc injectors
goal 600whp on E85 daily.
Old 04-29-2009, 10:32 AM
  #55
slammedobd1teg's Avatar
can i get some more info on wiring the fuel pump to have 14 volts?
Old 04-30-2009, 08:50 AM
  #56
boostedh22a's Avatar
Single Bosch 044 intank setup. 2004 Honda S2000. Custom hanger. Compared to the stock hanger with a drop-in Walbro. -6 feed/return. We've already made over 600whp and there is still a lot more head room for more.
Old 04-30-2009, 12:20 PM
  #57
kcevo's Avatar
Have any of you guy's looked into the Bosch 040 pump for in the tank vs. the 044?
There is no fitting/inlet on the bottom of the pump at all. The bottom of the pump is the entire filter/sock built into the pump. Will allow you to mount it lower in the tank as well if you are having issues.
Old 04-30-2009, 12:23 PM
  #58
tony1's Avatar
The 040 sucks, I sent one to Kinsler to get the flow data on it and it's not even close to an 044 in flow. The 023 is closer and in tank only, but still not as much as the 044.
Old 04-30-2009, 01:20 PM
  #59
kcevo's Avatar
Obviously better than a Walbro 255 right?
Can it operate at the pressure levels the 044 can?
From boschfuelpumps.com it shows the pump needing 6.5bar of pressure to get 300lph of flow where the 044 takes just 5bar.
Old 04-30-2009, 02:55 PM
  #60
96 GSR-T's Avatar
Tony do you have any experience with the B 261 205 413?
The only difference according to the Bosch PDF is the 044 is rated at 5 Bar and the 413 is rated at 8 Bar, I thought maybe this pump would be better suited to run 100 Base according to what they rate the 044 at. (or is the Bar figure what it takes to get to 200l/h of flow?)
http://www.bosch-motorsport.com/pdf/...mps/FP-200.pdf
Old 04-30-2009, 10:33 PM
  #61
Mr. Em1's Avatar
hey i like that setup you have their in your s2000 setup. NICE!
Old 05-01-2009, 01:05 AM
  #62
AdamB18C1EK's Avatar
Originally Posted by Mr. Em1
cool thats not a problem for me i was gonna take that out anyways!
haha. you say that now...there is a reason blown90 did his the way he did. and im realizing it now. first and foremost. it makes it alot easier to hear the pumps which is annoying. but secondly. if you dont have an exhaust on your car....the crap from your downpipe will come right up through that hole and into the cabin of your car. and believe me. the smell is not anything youre going to want to smell driving your car.
Old 05-01-2009, 01:25 AM
  #63
Mr. Em1's Avatar
thats why im running a 4inch straight back exhaust!
Old 05-01-2009, 02:23 AM
  #64
Turbocivic94's Avatar
That is one of the reason I went back to a simple setup for my car. I couldnt take the smell from exhaust any longer.
Old 05-01-2009, 03:48 AM
  #65
Blown90hatcH's Avatar
Yup. And the annoying sounds and crappy looks of an open hole, etc. To each his own.
Old 05-01-2009, 06:38 AM
  #66
tony1's Avatar
The walbro flows almost 500lbs/hr at very low pressures, like when feeding an 044.
The 040 flows 340lbs/hr at 1psi.
The 044 flows 518lbs/hr at 3psi.
The 040 flows 280lbs/hr at 40psi
The 044 flows 420lbs/hr at 40psi
The 040 flows 188lbs/hr at 100psi
The 044 flows 370lbs/hr at 100psi
The 040 flows 78lbs/hr at 140psi
The 044 flows 280lbs/hr at 140psi
This is all at 13v.
The 413 is the 'cream of the crop' 044, the 'motorsports' version. Supposedly hand picked of the best 044's and about 3-4 times the cost.
Old 05-01-2009, 07:26 AM
  #67
96 GSR-T's Avatar
I just found pricing on them, they were not that much more. But unfortunately you can only get them from a Bosch Motorsports Dealer and I dont think that exists in America.
Old 05-01-2009, 07:41 AM
  #68
sgnlab's Avatar
Originally Posted by captamericao9
Well Tony made 820 w/ 1600cc injectors and it sounded like it had some more in it so.... I think the dual walboro's can hang.
we made 831whp on a set of 1200's with an a1000! c16
Old 05-01-2009, 07:50 AM
  #69
tony1's Avatar
There are 2 Bosch Motorsports dealers in the US.
As far as the price difference, it can fluctuate quite a bit depending on where you buy things, but any way you look at it, they're quite a bit more.
Old 05-01-2009, 08:20 AM
  #70
noluckracing's Avatar
What kind of duty cycle?
Old 05-01-2009, 12:47 PM
  #71
I would imagine at that point they are just mechanical nozzles.
Old 05-01-2009, 03:18 PM
  #72
sgnlab's Avatar
Originally Posted by noluckracing
what kind of duty cycle?
97%
Old 05-01-2009, 05:50 PM
  #73
97%
Tick tick tick
Old 05-01-2009, 06:01 PM
  #74
sgnlab's Avatar
Originally Posted by Blown90hatcH
Tick tick tick
2 seasons! going on a third! good for 156mph
Old 05-02-2009, 01:37 AM
  #75
PPLH8R's Avatar
Here is another of the "BOMB" fuel cells I made for a customer of mine.
Quick Reply: **Post your Fuel System and Questions**
