**Post your Fuel System and Questions**
Old 04-24-2009, 05:48 AM
  #26
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: **Post your Fuel System and Questions**
i asked the question about pushlok or socketless hose. it is legal.
Old 04-24-2009, 07:37 AM
  #27
Mr. Em1's Avatar
cool i cant believe those actually work, thats awesome!
Old 04-24-2009, 08:57 AM
  #28
Mr. Badwrench
i should elaborate. i asked pat from nhra.
Old 04-24-2009, 09:08 AM
  #29
1992Si's Avatar
I think it say's in post #7 in this thread.
https://honda-tech.com/forums/drag-racing-36/fuel-cell-2545534/
Old 04-24-2009, 09:48 AM
  #30
naylor16's Avatar
my fuel setup for E85
-10feed -6return aeromotive FPR as well
mine is for 750-850hp
Old 04-24-2009, 12:56 PM
  #31
96 GSR-T's Avatar
^^^^ Is your goal 750+ on Ethanol with dual Walbro's? Interested in the results, I personally feel thats not enough pump for that power level and corn. What fuel filter is that?
Originally Posted by kte324
I got a question. I am currently running a intank walbro 255 and was going to do the intank walbro feeding a bosch 044 which I have heard good results from. I also hear about people doing dual intank walbros, but what about a my walbro intank feeding a walbro 255 inline? I have heard of it done before, but didn't know if it would support 650whp with rc1000s. Thanks. I am also unsure of what size feed line.
I ran the 255hp Intank feeding a 255hp Inline with RC1000's and it worked great, you should have no problem making 650hp with that setup. I welded -8 and -6 bungs on my stock cover and ran -8 to the Inline and -8 out to the rail with a pushlock -6 return, but you can use you stock feed as the return its basically -6 in size already. However the fittings on the 255 Inline are only M10x1.0 so you have to reduce the feed down to a -6 with the Intank/Inline Combo at the inline pump and then go back up to -8.
Ditching the Inline this year for an 044, I need a good amount of additional fuel for my new setup.
Old 04-24-2009, 04:13 PM
  #32
Redline130's Avatar
My fuel system set up:
Custom fuel cell made by Aka @ Hilo Speed & Service:
Fuel pump: Weldon 2025a
Regulator: Aeromotive
Lines: -10an
Fuel rail: Golden Eagle
Filters: Weldon pre and post pump
Injectors: RC 1200's
Current HP: 600 with room for improvement
Old 04-24-2009, 04:59 PM
  #33
kte324's Avatar
Thanks. I saw a good deal on a walbro inline which is why I was asking, otherwise I was going to do the bosch 044. How much did you make with the two walbros?
Old 04-25-2009, 01:34 AM
  #34
InDub's Avatar
Holy crap miller i could eat off the bottom of your car!
Old 04-25-2009, 04:50 AM
  #35
96 GSR-T's Avatar
The pumps held pressure at 550whp on Ethanol, and that typically requires 30% more fuel than gas so the 255/255 combo should be good for 700 depending on the dyno. Make sure you wire both pump with independent relays and the power to the Battery or Alternator.
Old 04-25-2009, 05:10 AM
  #36
Blown90hatcH's Avatar
Originally Posted by Mr. Em1
can you post some pics???? because this is the setup i wanted to run, do you think it is capable of 1000hp?
Originally the kit came with smaller 6" length lines. I didn't like how they rubbed on the sharp corners of the arms so I filed the arms smooth. Still I wasn't happy with it, so I bought longer lines.
You can see the -10 and -8 fittings welded on to the top of the kit so that I can have a true -10 and -8. Also, this allowed me to close the cover on the fuel pump.
I don't have any pictures of the lines under the car, but they go out the front and right down into the stock holders.
Old 04-26-2009, 11:17 PM
  #37
Mr. Em1's Avatar
oh i thought u meant the actual cover for the fuel pumps didn't close, so you mean the carbon fiber piece would not fit properly without running the 90's?
Old 04-27-2009, 05:05 AM
  #38
Yeah, the fuel pump cover (CF piece on mine) would not close without the 90s.
Old 04-27-2009, 09:45 AM
  #39
Mr. Em1's Avatar
cool thats not a problem for me i was gonna take that out anyways!
Old 04-27-2009, 10:00 AM
  #40
rip94delsol's Avatar
you have to run that cover! or make a cover yourself. there cannot be any exposed gas lines in the cabin with having a firewall or something to block it from getting into the cabin!
Old 04-27-2009, 10:07 AM
  #41
naylor16's Avatar
well with 1600cc injectors, i should get about that.
Ive talked to the guy in the drag racing for sale thread selling his blue si with a 42r on it, and hes running a similiar setup with e85 making like 832whp i believe, and he said he could have made more power on E85...so im guessing ill make what i want, but i will prolly stop between 750ish
Old 04-27-2009, 10:10 AM
  #42
naylor16's Avatar
thats how my pump is wired but.....what happens if one relay fails? then one pump dies and then possible leaning occurs causing detonation.....so i thought about 1 relay rated to handle 50A @ 12V, switch both pumps, 30A inline fuse on power to each pump......i think this would prolly be the best way to do it, this is what im changing mine too now
Old 04-27-2009, 10:55 AM
  #43
steeeve's Avatar
here is my set up.
Old 04-27-2009, 12:13 PM
  #44
96 GSR-T's Avatar
Interesting, 832 on E85 is the equivalent of 1100hp on Gasoline.... I dont see 2 Walbro's and a set of 1600's making that kind of power on Gas... who knows
Old 04-27-2009, 01:39 PM
  #45
uglyasscivic's Avatar
I maxed out my 1600cc between 800-900p on ethanol with the twin 044 pumps. I dont think the walbros can hang.
Old 04-27-2009, 03:10 PM
  #46
ALL IMPORT's Avatar
well when i had my single walbro setup i made 586whp on a mustang dyno. running rc1000s
the injectors were maxed out but it did it. always wanted to try a double setup & try to get 900whp but u would deff need 1600s. someone try it!!
Old 04-27-2009, 05:54 PM
  #47
naylor16's Avatar
well i guess once i get dynoed hopefully in about 2 months i will post the results and see what i maxed out this setup at
Old 04-27-2009, 09:44 PM
  #48
Mr. Em1's Avatar
bump for some legit setups!
Old 04-28-2009, 06:13 AM
  #49
captamericao9's Avatar
Well Tony made 820 w/ 1600cc injectors and it sounded like it had some more in it so.... I think the dual walboro's can hang.
Old 04-28-2009, 08:57 AM
  #50
96 GSR-T's Avatar
So you saying dual walbro's are going to hold the required fuel pressure to support 1100hp on Gasoline?
Quick Reply: **Post your Fuel System and Questions**
