FOR the $ : SLICKS or DRAG radials?
there's a BIG debate about this topic,which everybody knows that SLICKS is the only way to GO............................but for the $ will DRAG radials(BFG's) get you to a reasonable/respectable route without breaking the bank going with SLICKS?..........................................A LSO i cut a.625 light w/1.80 60ft pegleg on 22x8.5x13 M&H on VOLK TE37.................................POST your times on SLICKS/DRAG radials................................LET THE DEBATING BEGIN!
Re: FOR the $ : SLICKS or DRAG radials? (kamakaze1)
They are real close to the same price there bro depending on the size. There is no comparison in performance on a FWD car.
Re: FOR the $ : SLICKS or DRAG radials? (4piston)
well you would think the difference would be 60ft. and wheel hop depending on track condition and tire pressure.....................HHHMMMMMMMM!
Slicks for sure if you just plan to use them at the track. Keep in mind you will need somebody to go to the track with you to hold the slicks if you do get them.
1 Post
Price isnt even a concern in this case since cost is VERY similar.
Drag Radials are about $240-300 a pair dependon on the size, brand and where you get it.
Slicks are at the cheapest (22x8x13) are $250/pair and the common biggest size 25x8.7x13 are $320/pair.
All other sizes are in between.
So for price and performance comparison. Slicks are obviously the better choice.
As far as 60ft comparison, slicks of course will get you a better 60ft. Man, I've even cut a 1.99 60ft on regular Bridgestone Potenzas and those are regular tires.
