new 65# msd and 95lb msd made by siemen deka
Re: new 65# msd and 95lb msd made by siemen deka (b18bturbo)
And these just drop into Honda's without additional modification? I assume they are peak and hold and just as good a quality at RC eng injectors and the other ones you sell?
Re: new 65# msd and 95lb msd made by siemen deka (DarksideDC4)
yup these drop just in with no issues they are peak and hold reuqire resistor box.
Do the siemen deka work in Honda and aftermarket rails and manifolds? And do they use the OBD1 clips?
i bought the #72 a while back, they fit fine. all you need to do is use the factory o-rings. some cars that come w/o them may also need the spacers that go on the factory studs...for certiain fuel rails...
and this is a great price too.
Re: new 65# msd and 95lb msd made by siemen deka (downpipe)
The comprable 650cc RC injectors are $550 for 4 from camp1320, so this is a steal by comparison. Hell at $250, these things cost less than the 550cc injectors in camp1320's injector gb!
What kind of spray pattern...laser or mist? It almost seems to good to be true for $250. Anyone using them successfully in a street car?
Viren,
Are these as good as the 1000cc bosch injectors??
Do the bosch units require a resistor box like these do?
Adi
Re: new 65# msd and 95lb msd made by siemen deka (newgsr)
yes the boshc require resistor box just like these bosch and these work just as good as each other. new 110lb injectors will be out next week as well.
Well if these 95lb siemen deka injectors are just as good as the bosch 1000cc injectors the only thing this would mean is that,
I'm In!!!
Adi
we have 2 now need 8 more people and i can place this big order to get these prices.
these are good injectors, pattern is most likely conical and has better misting than the lucus/rc... i was even able to idle with stock ecu and 55lb, fit better than the rc and longer so it fits like stock injectors on the stock rail.
id be in for that price, thats hella cheap...where could i get a resistor box i know they come on older hondas, but i really have no clue what one looks like
oh and thanks darkside for the info
Re: new 65# msd and 95lb msd made by siemen deka (SpoolinLS)
No problem spoolin. I jes want me some kick *** injectors at a dirt cheap price.
You can get the resistor box at a junkyard, about 30-40 dollars. Looks like this:
