fully built jdm gsr 600+hp 4200
fully built jdm gsr with itr head...made 600hp on a small turbo...hit me up at 7025025229...will garuntee the motor is 100percent ready to go...once sell the motor will part the rest out
HEAD
-ITR head
-combustiom chambers opened to 84mm and fully blended
-KG Engine Builders turbo port
-aermotive fuel pressure regulator
-CTR cams
-Skunk2 pro series cam gears
-Skunk2 daul valve springs
-Skunk2 titanium retainers
-Skunk2 70mm portmatched throttle body
-hondata 4bar map
-Blox new TPS
-all sensors and vtec solenoid
-OEM dizzy
-MSD cap
-MSD wires
-MSD MSD coil
-1mm oversize stainless valves
-3 angle valve job
-all new OEM seals
-Edelbrock Victor X manifold, portmatched
-RS Machine thermal gaskets on IM and TB
-RS Machine cam seal
-goden eagle fuel rail
-id 1000cc injectors
BLOCK
-JDM B18C block
-RS Machines open deck sleeves
-RS Machines 84mm bored OEM p30 head gasket
-Energy Dynamics EnDyn 84mm rollerwave pistons, fully coated dome and skirt
-Eagle 89mm crank, OD'd to clear oil squirters and balanced
-Eagle LS rods w/ARP big bolts
-All oem Honda Bearings
-Apocalypse Power modified OEM oil pump
-All new OEM seals
-new OEM oil pickup
-new OEM water pump
-Moroso 5.5 quart steel pan
-Moroso pan studs
-Golden Eagle head studs
-Golden Eagle main studs
-Power timing belt
HEAD
-ITR head
-CTR cams
-hondata 4bar map
-Blox new TPS
-OEM dizzy
-MSD cap
-MSD wires
-MSD MSD coil
-3 angle valve job
-all new OEM seals
BLOCK
-JDM B18C block
-All new OEM seals
-new OEM oil pickup
-new OEM water pump
-Moroso pan studs
-Power timing belt
gsrhatch2356
Texas -OK -LA (Sales)
34
12-24-2010 12:09 AM
