FS: HOLSET HX40 Turbochargers - Genuine
I have two (2) Holset HX40w turbochargers off of "ISX" series trucks. Both are in great mechanical condition with absolutely no shaft play what so ever. Here is the break down on each:
1. First one has a frozen waste gate and will need to be repaired/replaced, or if you are running an external waste gate setup, this doesn't matter as you will be closing the flapper anyway. Also, the turbine retaining plate is missing. Again, minor issue that is easily fixed. See pictures. SOLD
2. Second turbo is in perfect shape with no issues at all other than some frozen turbine bolts on the v-band discharge flange where the down pipe would connect to. These should come out with a little penetrating lube and/or heat. $350 Shipped
Text/PM Greg for more information - (302) 359-2518
Innes
02-16-2007 02:30 PM
