FS: Good Stuff, JE Pistons B18c1, Custom Catch Can, ARP
ARP Head Studs
GSR B18C1....Also works with LS VTEC setups
Torqued a few times, just upgraded to stronger studs for the hell of it...these still hold just fine.
75$ shipped.
Catch can setup for sale...Bolts to a 96-00 civic driver side wheel well. It holds about a gallon and is baffled with 2 filters. It has 3 -8 ports on top that are where the AC dryer cylinder would usually be. I have 2 of the ports connected to the valve cover. Im selling the custom can with valve cover and lines to connect it.
$350.00
Pic doesn't show the filters in place because this was during fabrication...but there are 2 side by side, the same size as the "standard" catch can setups out there. It has a drain plug at the bottom.
75$ shipped.
$350.00
