Endyn Rollerwaves and Eagle Rods for d16y8
Old Oct 20, 2003 | 12:08 PM
vha27's Avatar
Default Endyn Rollerwaves and Eagle Rods for d16y8
The combo had 1000 miles on them
$700 shipped
thanks,
chris
Old Oct 20, 2003 | 12:39 PM
MikeMAN's Avatar
Default Re: Endyn Rollerwaves and Eagle Rods for d16y8 (vha27)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vha27 &raquo;</TD></TR><TR><TD CLASS="quote">The combo had 1000 miles on them
$700 shipped
thanks,
chris</TD></TR></TABLE>
links fixed for u
mike
Old Oct 20, 2003 | 12:48 PM
vha27's Avatar
Default Re: Endyn Rollerwaves and Eagle Rods for d16y8 (MikeMAN)
thanks man, thought imagestation was down
Old Oct 20, 2003 | 03:11 PM
Quad-Damag's Avatar
would these work for a y7, im thinking no
Old Oct 20, 2003 | 05:00 PM
vha27's Avatar
Default Re: Endyn Rollerwaves and Eagle Rods for d16y8 (Quad-Damge)
i would say yes however the c/r would be different due to the dish od the piston and combustion chamber design of the y7
bore and pin diameter are the same
Old Oct 20, 2003 | 06:57 PM
vha27's Avatar
Old Oct 21, 2003 | 08:24 AM
vha27's Avatar
and again...
Old Oct 21, 2003 | 10:23 AM
biassj's Avatar
what compression?
Old Oct 21, 2003 | 02:11 PM
vha27's Avatar
Default Re: (biassj)
cr is 10-10.5 :1 depending on resurfacing of block and/or head, as well as headgasket thickness used, according to endyn c/r is calculated respectively
(The compression ratio ranges given above were calculated using the bore diameters specified, stock strokes, stock combustion chamber volumes as given below, an 0.030" thick cylinder head gasket and piston-to-deck clearances of 0.020" and 0.000") check out http://www.theoldone.com for more info
Old Oct 23, 2003 | 05:59 PM
xenocron's Avatar
Default Re: (vha27)
Up for a friend!
Old Oct 23, 2003 | 07:55 PM
MyWhiteCivic's Avatar
Default Re: (vha27)
Are these 74mm? Trying to see whether they will work in a z6 also.
Old Oct 23, 2003 | 09:48 PM
vha27's Avatar
Default Re: (MyWhiteCivic)
75.5 mm, .020 overbore
Old Oct 23, 2003 | 11:02 PM
WeeMan's Avatar
From: Put it in..Take it out... Put it in..Take it out, United States
what would the compression be with these pistons/rods in a dohc zc, also would they work?
Old Oct 27, 2003 | 02:25 PM
vha27's Avatar
Default Re: (EGizzleC1)
not familiar with the zc, as long as the bore is the same i dont se why not, ud just have to gigure out the c/r
Old Oct 28, 2003 | 02:39 PM
vha27's Avatar
Default Re: (vha27)
forgot to add, u will need to bore out your cylinders .020" to clean up the cylinders
Old Oct 28, 2003 | 06:10 PM
vha27's Avatar
Default Re: (vha27)
pistons have been seperated, $375 shipped to your door
Old Oct 29, 2003 | 08:40 AM
vha27's Avatar
Default Re: (vha27)
woo woo
Old Oct 31, 2003 | 10:40 PM
vha27's Avatar
Default Re: (vha27)
cmon bump, bump, bump it up
Old Nov 1, 2003 | 01:25 PM
dubniK's Avatar
still available?
Old Nov 1, 2003 | 03:14 PM
vha27's Avatar
Default Re: Endyn Rollerwaves and Eagle Rods for d16y8 (slow ek)
still available
Old Nov 3, 2003 | 01:33 PM
vha27's Avatar
bump $350 shipped
Old Nov 5, 2003 | 12:54 PM
vha27's Avatar
bump
Old Nov 5, 2003 | 01:55 PM
EX-T's Avatar
Would you be willing to split the combo up?
Old Nov 5, 2003 | 03:56 PM
vha27's Avatar
Default Re: Endyn Rollerwaves and Eagle Rods for d16y8 (DSeriesBKilla)
it has been split
Old Nov 5, 2003 | 04:45 PM
ghettocrxsi's Avatar
Just a little FAQ. You can only use the y8 pistons with a y8 head. It will not work with the z6
