B18c with built head
Old Jul 4, 2019 | 01:40 PM
BoostHatchFreak's Avatar
Default B series engines
I have a gsr stock short block rebuilt never fired with a gsr head with blox springs blox p1 cams sk2 valves blox cam gears top end has 2000 miles on it 2200 obo will sell separate. 1050 short block, 1150 head
Also have a ported p72 head stock valves super tech springs retainers I can put the cams in instead 1350 with the blox cams and gears have p72 rods with p73 usdm pistons 2000 miles 150
gsr pistons and rods, pistons no good 40.
set of b20 piston and rods good shape 40
b series ram horn t4, s366sx3, 3" up pipe, 1.5" dump tube package deal 850
b series cast t3 manifold, gt3040r turbo .63 ar 5 bolt, 3" 5 bolt dp, dump tube package deal 540
no name 38mm waste gate two bolt 40
tail 38mm waste gate two bolt needs diaphragm 150
Bosch 210lb injectors with top hats and plugs 500
b18b1 runs good could use a rebuild down the road 400
set of cp 84mm 22cc turbo pistons on arp full floating pr4 rods one is a little hurt 350
RC 310cc injectors been sitting awhile 150
have quite a few p06 and p28 ecu chipped and virgin lmk if interested.
Pm if you’d like, thanks for looking time to clean out the garage and finish my build.
Old Jul 6, 2019 | 10:30 PM
Default Re: B18c with built head
Blox non ported p72 head
Old Jul 6, 2019 | 10:47 PM
Old Jul 6, 2019 | 10:51 PM
Ported p72
Old Jul 8, 2019 | 08:49 PM
updated
ngv1515
Feb 20, 2019 08:24 AM
ChristosDc2
Jan 15, 2019 10:45 AM
hello1320
18
Dec 14, 2010 09:50 AM
badassmthr4000
Apr 5, 2007 09:46 PM
B6tizzleHatch
Jan 5, 2007 12:27 PM
