Classic Hondas All Pre-1988 Hondas.
write up of De-vac
Old Jun 26, 2007 | 02:50 PM
generallee01's Avatar
Default write up of De-vac
Could I get a write up of how to do that De-vac thing? I saw that HBK:CRX did it with his civic and his is the exact same as mine. I just need to know first, I live in PA so will it affect emissions or anything to do with inspection? If it wont, then I just need to know what to take off and plug and what not to plug. just so you know I have a 1987 civic si 1.5 pgm-fi. Thanks.
Old Jun 26, 2007 | 03:03 PM
phatboycrxhf's Avatar
Default Re: write up of De-vac (generallee01)
i know it does for carbed cars ,but unsure for FIcars check out http://www.redpepperracing.com and search Devioncrx he has done it to his hatchback ,and allso search fi devac ,its on there
good luck
Old Jun 27, 2007 | 05:35 AM
ok thanks
Old Jun 27, 2007 | 10:02 AM
will I need it for emmisions or inspection tho? because I live in PA and I was wondering if I need it.
Old Jun 27, 2007 | 10:29 AM
smithenhiven's Avatar
11:11
Obviously since you car is older than any OBD testing, they will have to put the tester up the tail pipe to check the emmisions output. So as long as de-vacing the car doesn't affect emmisions (I don't know if it will or not, but probably not), you should be fine.
Old Jun 27, 2007 | 02:09 PM
thanks
Old Jun 27, 2007 | 03:09 PM
well when it comes to a carbed crx ,when devacing ,it makes it so the secondary will open sooner ,well pretty much as soon as you give it throttle ,and makes your car run off only like 3 vacume lines the millon it had before lol while looseing the black box on the fire wall
as for the fi version,im pretty sure you remove something from the black box on the drivers side and loose the black box on the firewall
you'll have to look because im not sure if it will effect the emissons test ,i'm pretty sure it does though ,since your car will run a bit richer
ummpwr
Northeast
Apr 4, 2009 11:10 AM
px_R
Feb 6, 2006 02:01 AM
FakeJDMEF8
Sep 4, 2005 07:52 AM
Mike813
Jan 21, 2004 03:56 AM
turbod16y8
Sep 21, 2002 02:05 PM
