Classic Hondas All Pre-1988 Hondas.
why?
Old May 11, 2009 | 10:03 AM
Bright13's Avatar
Default why?
Having trouble with my '84 CRX, yesterday it was running fine, and I replaced the valve stem seals and other components on the auxilary valves, got it put back together, and now it wont start. Its getting fuel, and the plugs spark. If its pushed it will start, but doesnt have as much power as it usualy does and dies when the clutch is pushed in. Any ideas or suggestions?
Thanks,
Morgan
Old May 11, 2009 | 01:51 PM
von1988's Avatar
New User
Default Re: why?
Did you check your Valve lash and put it back to specs? Also is all your wiring connected. All grounds?
Old May 11, 2009 | 03:36 PM
cbstd's Avatar
Default Re: why?
Cam timing issue
Old May 11, 2009 | 11:56 PM
2ndGenGuy's Avatar
Default Re: why?
Originally Posted by cbstd
cam timing issue
+1
Old May 12, 2009 | 02:59 PM
Bright13's Avatar
Default Re: why?
There wasnt any compression, and I found that the exhaust valves were staying opening, so I adjusted the rocker arms, and it ran fine. I took it for a good test drive, and it ran good. Then when I was driving it later, I went after a stop light and it had different problems. It was late last night so I havent had time to work on it again, although it seems to be running really lean. Any ideas on the new problem? Thanks.
Old May 13, 2009 | 09:50 AM
cbstd's Avatar
Default Re: why?
Have you been driving your old Honda "enthusiastically?"
There is a VERY good chance that your timing belt has slipped a tooth because #1- your timing belt is old #2- you have revved the enigne hard
And even if you think that everything is OK with your timing belt, it is a good idea to check your cam timing when your car presents symptoms like this.
Scott
Old May 13, 2009 | 05:07 PM
Bright13's Avatar
Default Re: why?
Its a fairly new timing belt, and I drive it normaly except for the occaisional hard run just to make sure everything is working properly after fixing things. I changed the fuel filter by the gas tank and it seems to be doing alright now (fingers crossed).
Old May 13, 2009 | 05:56 PM
cd6brenton's Avatar
Default Re: why?
just do a swap its an 84 stick with old school thought dohc zc
STATek9
21
Oct 4, 2009 09:33 AM
swapped95
19
Sep 30, 2007 06:29 PM
jdmjeff
15
Apr 26, 2007 12:58 PM
