Classic Hondas All Pre-1988 Hondas.
Problems
Old Jan 26, 2010 | 04:33 PM
CRX Toad's Avatar
Default Problems
THIS IS POSTED FOR SP SHILL WHO IS TRIAL
Originally Posted by sp shill
Im new to this forum as well as a 87 crx si owner, I am trying to get my crx to meet all the break and light inspection spec to get the car registered and ran into the problem of both my head light lever as well as the wiper lever connections. basically the previous owner ghetto rigged both levers into the steering column with tape, eventually both became inoperable. see pix, so far i have removed the housing around the steering column, steering wheel, ignition etc... and I have finally hit a wall while trying to disassemble the mechanisms for the signals lights etc.. basically can i replace this whole assembly or is there some way im not finding to further disassemble the black mechanism so i can repair it? (see pix link) p.s. if you could possibly paste this over to a new thread i would appreciate it because im still in trial but need help to fix this problem asap
http://www.postimage.org/image.php?v=Pq5DpkS
http://www.postimage.org/image.php?v=TsJeab9
Old Jan 26, 2010 | 05:52 PM
E-AT_me's Avatar
Default Re: Problems
replace the whole assembly.
Old Jan 28, 2010 | 10:14 PM
MFH87CivicSi's Avatar
Something doesn't look right - I think the lever only needs to be replaced - and I also think that some of it is broke off in the column assembly still. E-AT me is right if I'm not - But that lever your holding should have a mass on its opposite end which should slip into the assembly on the column. More than likely has to be ordered. Good luck - Post results!
Old Jan 31, 2010 | 07:56 PM
sp shill's Avatar
New User
the levers appear to be in working order but your right there is a a broken piece of plastic from where the lever attached. when i got the car this whole thing was ghetto rigged with medical tape and actually functioned for a while when the tape wore out holding it together it fell apart. Ive been searching around the web trying to find the part but have had no luck. can anyone recommend a place i might be able to find this part (or even what the parts called) online or by order.
Thanks guys your a great resource
Old Jan 31, 2010 | 09:45 PM
Go to google - Enter 'used honda parts + your city/state/zip + junk yards', etc...
on my car its called the "Combination Switch", it contains the wiper, washer, headlight switches as well as the turn signal actuator.. Like danger says, go to a j/y or call one. Sometimes new is your best deal... Shop around - and if your going to be doing this stuff I strongly suggest you get a manual - it will really help!
Old Feb 2, 2010 | 08:23 PM
dangercartjason's Avatar
dude i would just find a whole new assembly from a junk yard and start clean instead of keeping messing with a hot mess.
jDmM@NnY
Mar 3, 2011 09:02 AM
jlicrx
Jan 26, 2010 10:51 AM
volcomstoned
Suspension & Brakes
May 13, 2008 12:38 PM
dethx88crx
Mar 9, 2008 07:46 PM
camera obscura
Sep 16, 2003 01:47 AM
