hey just joined here
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
Hey figured I would join up, have a 1986 Accord hatchback full custom job that's being rebuilt again right now, few engine pictures, the SU's are being mocked up at the moment, don't pay any attention to any loose wires or hoses, when everything fits it will all be in it's proper place.
Re: hey just joined here
there is plenty of room i don't see any problems with this engine, as far as the entire car, haven't updated the site for a while, need to get busy on it, but some pictures on here. a lot of stuff has gotten updated or changed since my last site update. http://losts86hatch.tripod.com/
I can put my hand between those air cleaners and the firewall, you are splitting the air requirements of a 2.0 liter engine between two carbs, there is plenty of room, it's not like I had tons of room to work with in the engine compartment, it's not that complex either, I guess it looks that way to others because they didn't design it, but it's really not. I went through about a dozen prototype air cleaners before I figured out something that would work. Those are aluminum aircraft tailwheel hub halves, modified into air cleaners. they have velocity stacks and the filtering is done with oiled foam filter material, there is a heavy perforated stainless piece that fits in each one,and secures with a snap ring. this holds the foam element in place. If it comes down to it i can drill additional air holes around the perimeter of the filter, but i doubt it will be needed. The car had an excellent oil separator and pcv system so i kept that, keeps the oil nice and sludge free, and i kept the canister for the fuel bowls and made it work. I don't care about wasting gas while driving, but no point it letting it evaporate out of the tank and fuel bowls while the car is sitting. that's just money going up in the air. I also have an oil cooler setup, just waiting to get an oil thermostat to finish hooking it up. no room for it in front so it uses a Bosch squirrel cage blower to force air through the cooler when needed. the rest of the stuff are just coolant hoses and other lines I 've converted to AN stuff instead of rubber hose. the thing next to the throttle cable allows one cable to pull both chokes in sync with one cable. Bit of engineering in that, tested it and it moves smoothly with no issues.
that's a good way to put it, pretty much everything on the car is roll your own. If you look close you'll see the power steering reservoir is made from an old aluminum army canteen. lots of stuff like that on the car. the vacuum storage bottle is an old fire extinguisher for example, no where to put it under the hood, so i made some brackets and mounted it to the floor right in front of the rear seat. waiting on the money to get an odyssey battery, I didn't have room under the hood due to the cooler in it's place, so i turned an old tool box into a battery box, all the fuse blocks that are added on are in there, as well as the main breaker right off of the battery. painted it black, got some vintage Honda patches, and scored a really rare Nelson Dunn aeroquip decal, from the eighties, as well as a huey lewis decal. it bolts behind the passenger seat through the floor pan. No one ever uses the back seats anyway. One of my trick items. I think that Odyssey battery might weigh 20 pounds? Really all that's needed in a small car like this
hahahahahahahah I have to post this entire page on three geez, at least he laid off the spray paint, hes gotten much better over the years, used to be all fart cans and big wing talk, he's matured a lot, all the flaming over there has straightened him up pretty good. He still may turn out just fine. For a while there I thought some of us were going to have to fly out there and beat him severely with an apc park bench wing, but he grew up.
I measured, the firewall isn't exactly flat, but i have about six inches between the aircleaners and the firewall, plus another air gap between the velocity stacks and the edge of the aircleaners.
thanks,it's slowly coming together. been trying to find raised white letter tires that fit it, and they no longer make them in my size. 195-60-14 or something that will fit. i wonder how how good raised black letters would look painted white with a tire lettering pen?
not really, oil system,fuel system,cooling, few vacuum lines, pcv system. I added a couple of things like making the vapor canister work vs. the car reeking of fuel when it sits on hundred degree days, and I added a catch can for the pcv system. Turbine aircraft engine looks complex too unless you understand it,then it's straightforward.
