87 crx nose panel
87 crx nose panel
I've seen aftermarket stuff for this header panel. It seems that the CRX and the Civic coupe share the same panel, but the Civic sedan does not? Is it just that the grill is different? Or won't fit at all? And, is there a separate grill that needs to be purchased if I only get the header? Thanks. Mike
Re: 87 crx nose panel
Yes, hatchback, my bad. I figured it wouldn't work - the hatchback nose is 18 bucks aftermarket, the CRX is near 100 bucks. Do you know of a better source new/used? Thanks. Mike
i say search some junkyards, but more than likely you'll end up finding broken ones. either ebay or the one piece carbon fiber hood if you want to go aftermarket..
deftones1868
09-17-2007 02:35 PM
