The great Honda del Sol Part Out
Parting out my 1996 Honda del Sol
This was a 400WHP monster, cylinder 1 blew up and I cannot jusitfy the cost of getting her back up and running. Everything is for sale. I can't be bothered to post prices for everything, there is too much to list.
PM me with offers, lowballers will be ignored. All parts located in Mississauga.
PDF Parts Link:
http://www.steveandemily.com/delsol/del_sol_parts.pdf
Mini-Website with some images (most not current)
PDF Parts Link:
Re: The great Honda del Sol Part Out
More images added today. Flywheel, Clutch, ITR Tranny, Starter
Guys, you really need to open the PDF, there are 3 pages worth of parts in there.
OEM Rear Spoiler
(2) Carbon Fiber Hoods OEM Style + SS Style
JDM License Plate Panel Fillers (Rear)
Volk Rays TE37 16x7.0 + 42 White
TOYO T1S 225/45/16
Lightweight Lock Nuts
Willwood 4 Piston Calipers w/Race Pads (Front)
12.1" Drilled Rotors (Front)
AEM OEM Calipers w/EBC Pads (Rear)
11.1" Drilled Rotors (Rear)
Wilwood Braided Steel Brake Lines (Front)
1 Piece Headlights
6000K HID H4 Bulbs
B16A1 VTEC 1.6L Block (Damaged, needs 0.5mm overbore to use)
Skunk2 Turbo Stage 2 Camshafts
BDL Adjustable 5 Point Intake Cam Gear
Ferrea Oversize Valves (+1.00mm)
Skunk2 Titanium Retainers
Skunk2 Super Alloy Valve Springs
JDM Red Valve Cover
Skunk2 Billet Throttle Body 70mm
Skunk2 Cast Intake Manifold 68mm
Greddy Adjustable Blowoff Valve 40mm
Precision Turbo 350HP Intercooler Air-Air Bar & Plate
Garrett GT3076R .63 A/R Ball Bearing Turbo
Stainless Steel Intake Piping
HKS Mushroom Style Air Intake Filter Kit
Greddy Stainless Steel Catback Exhaust 70mm
DMH Performance Electronic Dump Valve 3.0"
Stainless Steel Down Pipe 3.0"
Stainless Steel Ram Horn Turbo Manifold
Turbosmart Ultragate Wastegate 38mm (14 PSI Spring)
M&W Pro14 CDI w/300m Coils
T1 Motorsports Cam Trigger Kit w/Exhaust Cam Gear
B16A Starter Motor (OEM)
Walbro 255lph In Tank Pump
Magnafuel Fuel Pressure Regulator
Precision Turbo 880cc Low Impedence Injectors
BDL High Flow Fuel Rail
Russell Stainless Steel Braided Fuel Lines
Flex-a-lite Radiator Fan Slim Profile
Flex-a-lote Oil Cooler
Mishimoto Radiator Aluminum
Clutchmasters Stage 3 Clutch (50% Life Remaining)
Clutchmasters Lightweight Flywheel
ITR LSD Equipped Transmission
B&M Short Throw Shifter
Skunk2 Pro Series Camber Kit +/?4° (Front)
Ingalls Camber Kit (Rear)
Skunk2 Lower Control Arms (Rear)
Neuspeed Anti-Sway Bar (Rear) 22mm
Upper Strut Bar (Front) (OEM)
DC Sports Upper Strut Bar (Rear)
SPAX Coilovers (Height & Dampening Adjust)
AEM 3.5 Bar MAP Sensor
AEM Wideband O2 Sensor (Single Channel)
AEM 19 in 1 Serial Datastream Gauge
AEM Standalone OBD2 Programmable ECU
Turbosmart e-Boost Controller (40PSI)
Autometer C2 EGT Pyrometer w/52mm Gauge
Autometer C2 Fuel Level Gauge 52mm (OEM Deleted)
Autometer C2 Oil Pressure Gauge 52mm Electronic
A'pexi Boost Gauge (Vacuum - 30 PSI) 60mm Mech
A'pexi Oil Temp Gauge (0 - 140°C) 60mm Elec
White Face (Indiglo Illumination) Cluster
Blinder Laser Radar Jammer
Alpine Multimedia Touch Screen Head Unit
Alpine Navigation System (2010 Map Data)
Alpine IMPRINT Audio Processor
Alpine Bluetooth Module
MB Quarty Component Speakers & Tweeters (Front)
Alpine Coaxial Speakers & Tweeters (Rear)
Polk Audio 4/3/2 Channel Amplifier
Door Panels Re-Upholstered (White/Black)
Rear Panel Re-Upholstered (White/Black)
Seats Re-Upholstered (Grey/Black) (SPARCO Alcantara Fabric)
OEM Floormats (del Sol Logo in Rainbow Color)
Sparco Trium Steering Wheel (Airbag Deleted)
Sparco Steering Wheel Hub
Sparco Race Pedals (Billet Aluminum)
JDM Door Map Reading Lights
Triple Gauge Pillar (52mm) (Custom)
OEM Rear Spoiler
TOYO T1S 225/45/16
1 Piece Headlights
6000K HID H4 Bulbs
JDM Red Valve Cover
Sorry, but I'm not shipping any of this stuff outside Canada, This is why its in the Canada regional forum.
Wow...I remember I asked you for the shell on torontocivics.com a year ago (Well, at least 8 months) and your still holding onto it?
Why not lower some of your expectations on price and get rid of this thing faster.
Good luck...and I hope for myself I don't ask the same question next year....
