Brakes
Click Here
Brake FAQ
Old Aug 29, 2008 | 08:55 AM
nsxtasy's Avatar
H-T Order of Merit
Default Brake FAQ
List of Brake Fluid Boiling Points and Prices
Stoptech White Papers, including:
The "Warped" Brake Disc and Other Myths of the Braking System
Pad and Rotor Bed-In Theory, Definitions and Procedures
Old Sep 3, 2008 | 09:43 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Brake FAQ (nsxtasy)
Regarding refinishing rotors, new and used
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by American Honda &raquo;</TD></TR><TR><TD CLASS="quote">
American Honda requires refinishing of the front brake
discs with an on-car brake lathe that mounts to the
steering knuckle. Use of an on-car, steering knucklemounted
lathe is critical because it corrects runout of
the hub and disc as an assembly. Experience has
shown that very small amounts of runout, not felt as
brake pulsation initially, will grow and become
noticeable as the discs are subjected to heat and wear
over time and mileage. That is the reason for the
requirement to refinish new brake discs.
Old Oct 14, 2008 | 09:54 AM
BrakeExpert's Avatar
Default Re: Brake FAQ (Evs-One)
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
Old Jun 26, 2009 | 06:44 PM
KWayRacing's Avatar
When changing a master cylinder. Always make sure the seal either comes off withthe brake master cylinder(which it will not) or that you remove it from the brake booster where it will be stuck or otherwise you will have a spongy pedal headache.
Old Jul 10, 2009 | 11:43 PM
SmellsLikeMustand's Avatar
Had this problem thought it was the booster. also, if your paddle is soft after bleeding the entire system it must mean you have a slow leak at the fittings or still have air. Check your fittings at prop valve, master cylinder and brake caliper and hard-lines. It also might be your master cylinder or booster is bad. If your booster is bad you might have idle issues or vacuum leak coming from booster. Go under the peddle and try to hear it. Check service manual for booster checking guide. Check all your fittings that were opened you will see the leak if you didn't put on the fittings on good. Peddle must be solid after changing brake parts. Make sure to bench bleed master cylinder. Will save you much time and headache if you don't do it. Always make sure to check for leaks. Mark the master cylinder with a marker and check for leaks every few days to see if you have any leaks.
Booster replacement tips.
Before BOLTING on the booster make sure you adjust the lock nuts to the appropriate length so that it matches the Brake Peddle and the Brake Light is OFF. Before putting on the master cylinder start the car and make sure you don't hear a vacuum leak. If you do you have a leak at the booster somewhere. If no leaks, then put on the bolts on the booster inside the car after its all aligned with the Brake Peddle. Make sure to adjust the booster to brake peddle first. If you don't it will impossible and you will need to take everything off again. Its a bitch on EF the left top. Need someone with a steady hand and use 1/4 extension with socket. Make sure to put the cotter pin and bolt for the booster to the peddle.
Extra tip EF SI: make sure to take off that vacuum port on the EF's Si on the left held by 10mm bolts. This will make the booster install very easy. Remove the speedo cable and move the gas lines. Take off the booster bracket above the booster.
Make sure to adjust the brake booster push rod to appropriate length or else your brake calipers will get stuck after driving for like 10-15min. No fun. Need at least 5-6mm clearance when you press the brake peddle when it becomes hard.
Be safe friends.
enjoy feel free to pm if this helped you out..Question feel free to ask. No charge involved.
Hare Krsna!
Old Jul 23, 2009 | 06:21 AM
bzuka's Avatar
New User
Old Oct 17, 2009 | 10:01 PM
cr8ter's Avatar
actually brake expert with hondas it does not matter how u bleed it....i use to think it did but according to my honda instructor at the training center in french camp ca it does not matter how u bleed the system....
Old Oct 17, 2009 | 10:03 PM
cr8ter's Avatar
also if u have soft pedals check calipers sliding pins and make sure they move in and out freely
Old Oct 21, 2009 | 08:54 PM
gsrjdmb18c's Avatar
where can i get an on car lathe?
Old Nov 21, 2009 | 06:55 PM
old no.7's Avatar
http://www.hunter.com/pub/product/lathe/index.htm
Old May 2, 2010 | 09:17 PM
Spawne32's Avatar
that stoptech "myths" section is such complete an utter bullshit, i cant stand it when people try to use that as an argument. While pad deposits do cause vibration and is a real problem, many people use that stoptech article as a claim that cast iron rotors cannot physically warp, which is just not the case, all metal that is constantly heated and cooled is susceptible to warping, ive had rotors come off cars that were so badly warped you couldn't get them to sit level on the ground.
Old May 7, 2010 | 08:51 AM
Mikey3000's Avatar
Who the hell are you? I'm more likely to believe Carroll Smith, the author of that article, than you. He was a very accomplished racing engineer is whole life and even helped ARP design fasteners. Just because material undergoes high temperature operation doesn't mean it'll warp. It's when that material isn't under uniform pressure during the high temperature that it warps. Rotors are clamped evenly on both sides, barring abnormal circumstances, during their operation and hence, no warpage!
Old May 7, 2010 | 09:37 AM
Spawne32's Avatar
Do some actual mechanical work on cars and you will realize the inherent flaw in that article...
In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures.
Im not gona argue the fact that pad material transfer doesnt cause problems, but almost EVERY case of "warped disc brakes" ive worked on has been exactly that, the rotor itself was noticeably warped.
Saying that cast iron rotors dont warp is complete bullshit, in fact they are 10x more likely to warp on regular cars under regular driving conditions then they are on race cars due to the variations in how the brakes are used.
Old May 10, 2010 | 10:12 AM
mike in atlanta's Avatar
I would agree. I have been working on cars since the age of 8 when I was just holding a work light for my dad under his Citroens. At the age of 40, I've warped quite a few rotors over the years from 1 ton trucks to my old M3 Lightweight race car. The stoptech article is and can be useful but they are also incorrect in stating that their theory is fact for most 'warped' rotors. I too have seen many rotors warped bad enough that they would not sit flush on a table. On the other hand I've had many rotors that only need a pad change and proper break in to cure the shimmy most think is caused by a warped rotor.
I am also old enough to know that even the experts can and do get it wrong at times. Otherwise I would not be here trying to track down why my GF's 06 accord brakes are sticking/dragging.
Old May 16, 2011 | 09:12 AM
OldSKooL-eK's Avatar
anyone know the line size and the fitting size i need to replace my line?
blew near the front so i am tapping in at the prop valve to where the line gets solid and i know it wont blow.
much appreciated.
i will keep googling aswell.
Old Oct 1, 2011 | 05:33 PM
photog72's Avatar
Can you show me a link or source for this? I will be bleeding my wife's '04 Civic brakes, and have been bleeding brakes on other cars using farthest to closest.
Old Dec 16, 2011 | 09:02 PM
95CTR's Avatar
not saying i know all there is to know but i also have always done the farthest to shortesst technique, however i only use that on NON-ABS vehicles, because there are parts in those systems that can get messed up if not bled correctly
as far as the warped rotor topic i have only ever warped one an it was cause i was hard on the brakes and i went through a huge unavoidable puddle while they were still very hot, ive also had one crack from a similar occurence. i also know that on rear disc cars, if you set the parking brake while they are still hot it wont allow them to cool evenly which can (but not alway) cause them to warp.
also, i agree with who ever said it before about having proper bed in on the brakes, this makes a big differance in how they perform through out the life of those parts.
if you have a spongy pedel and you have checked for leaks, and you have no fouled parts (i.e. vacum leaks, fluid leaks, ****d lines or worn out soft lines) then start out by changing your fluid, it may be something as simple as having too much moisture absorbed by the fluid thats in there now. you might say "well the fluid still looks clean" that has nothing to do with it. because honestly if your fluid is dark and gross looking you should have changed it long ago.
but those are my thoughs on the thread so far, feel free to chime in with more stuff, like i said im no expert im just sharing from my experiance and independent research.
Old Feb 2, 2012 | 12:42 PM
361 accord's Avatar
interesting arguments in here but i gotta get some straight info. or at least hear a couple other peoples opinions
i have new baer decelarotors and hawk ceramic pads to install and i want to do the best i can since its my first brake upgrade
so what is the best way to bleed the system for a 2000 accord ex, 4x disc ABS ?
i did mine from furthest to closest but someone here said it has to be done an unusual way, someone said just do it like always (far-close) and another said go in whatever order you want??
* what i was orginally trying to find, what's the best grease/lube for the calipers? i mean one specific product thats better than the stupid little packets of disc brake lube from autozone
*it cant hurt to grease pretty much everything in sight can it, like the boot around the piston?
i was wondering about the break in periods being different for pads and rotors and stuff and not wanting to shock the crap out of my new rotors, i found this
Old Feb 2, 2012 | 01:35 PM
361 accord's Avatar
rotor is first priority and is better to not rush into seasoning or bedding, especially on a street car
Originally Posted by baer
Seasoning Procedure:
Before you begin, please note: The following represents the minimum recommended, “Seasoning” process. If your situation offers any opportunity to perform gentle preliminary “Seasoning” outlined in Step 2 below for a longer period of time, this will
generally render even better performance and increase further long-term rotor life.
Use the vehicle for 5 to 6 days of gentle driving. Use the brakes to the same extent that you used the stock brakes, DO NOT TEST PERFORMANCE or ATTEMPT HEAVY USE UNTIL ALL ITEMS OUTLINED HAVE BEEN COMPLETED. It is imperative that excessive heat is not put into the rotors at this stage. They need temperature-cycling to relieve the internal stresses.
Note: Zinc plated rotors (which are an extra cost option) need a couple of extra days of driving to wear through the plating before “Seasoning” actually will begin. Find a safe location where the brakes can be run to temperature. Your goal is to gradually increase brake temperatures with progressively faster stops.
Start by performing four 60 to 70 mph stops, as you would in the normal course of driving.
Next, perform four medium effort partial stops (about 50 %) from 60 mph down to 15 mph. Follow this with five minutes of freeway driving with LITTLE to NO BRAKING to allow the rotors to cool.
Then, perform four medium-hard effort partial stops (about 75 %) from 60 mph down to 15 mph. Follow this with ten minutes of freeway driving with LITTLE to NO BRAKING to allow the rotors to cool.
Park the car and allow the brakes to cool overnight to ambient temperature. You are now 50 % done with the rotor “Seasoning/Bedding” procedure proceed to STEP 4 the following day.
Return to the safe location where the brakes can be run to temperature. Make sure the brakes are warmed to full operating temperature and then, perform four medium effort partial stops (about 50 %) from 60 mph down to 15 mph. Follow this with
five minutes of freeway driving with LITTLE to NO BRAKING to allow the rotors to cool. Then, perform four medium-hard effort partial stops (about 75 %) from 60 mph down to 15 mph. Follow this with ten minutes of freeway driving with LITTLE to NO BRAKING
NOW, make six HARD partial stops from 60+ mph down to 15 mph or until rotors have reached an operation temperature of between 900 and 1,100° (Note: Temperature paints to accurately measure rotor temperature may be purchased from Baer Racing). Every effort should be made to perform this procedure without locking a wheel. Follow this with ten minutes of freeway driving with LITTLE to NO BRAKING to allow the rotors to cool.
Let the system cool off over night. The rotors are then ready for the next step in Preparing your Brake System: Bedding Pads.
baer- rotor seasoning
Originally Posted by baer-pad bedding
Bedding brake pads has a couple of important effects. The friction material in semi-metallic pads is held together by an organic binder, usually a type of phenolic material. As the pads get hot, the binder boils and burns from the top surface of the pad. Once this burning or “Bedding” takes place, the friction material makes proper contact with the rotor.
Baer ClawŽ systems feature Baer’s ceramic-based SPORT TOURING “D-compound” brake pads. Although pre-burnished from the factory, SPORT-TOURING, just as with all pad types, benefit from being properly mated to the rotor surface. If both the rotor and pad are new and the rotor surfaces are un-plated, it is most desirable to run the pads through normal commuting type driving for at least 150-200-miles before using them aggressively. If the new rotor surface finish is plated or the rotor is used with a compound other than the SPORT-TOURING ceramic-based pad, increase the commuter type driving with no hard use, to a total of 250-300-miles to accomplish the blending of the pad surface to the rotor surface.
Bedding The Pads - (NEVER DRAG the brakes)
Note: Never “Bed” pads on rotors, which have not first been “Seasoned.” Always allow a substantial coast down zone when bedding pads that will allow you to safely drive the car to a stop in the event of fade.
1.Perform four-repeated light to medium stops, from 65 to 10 mph, to bring the rotors to temperature.
2.Perform three light stops in succession. Perform eight heavy stops, back to back, at a point just pending wheel lock, from 65 mph to about 5 mph.
3.Drive for ten minutes to create cooling airflow, without using the brakes if at all possible.
4.Perform three light stops in succession. Perform eight heavy stops, back to back, at a point just pending wheel lock, from 65 mph
to about 5 mph.
5.Drive for ten minutes to create cooling airflow, without using the brakes if at all possible.
Additional Notes:
◦Metallic brake pads – Metallic pads need high temperatures to keep the pad “Bedded”. If you drive the car for a period of time without using the brakes extensively, you may need to “Bed” the pads again. This is not a problem. Simply repeat the procedure.
◦Switching from Carbon Metallic pads to semi-metallic brake pads (not recommended) – When switching from Carbon Metallic pads to semi-metallic brake pads will need to wear through the layer of carbon that the PFC pads have deposited in the rotor surface. The new pads won’t grip well at all, until this layer of carbon is removed.
◦Racers - Racers should “Bed” a few sets of pads at a time. In the event you need to change brake pads during a race, you MUST use a set of “Bedded” pads. Racing on “non-bedded” pads leads to a type of “fade” caused by the binding agents coming out of the pad too quickly. This is called “green fade”. These binders may create a liquid (actually a gas) layer between your pads and rotors. Liquids have a very poor coefficient of friction. This condition is the reason for reverse slotting or cross-drilling rotors, as it allows a pathway for the gasses to escape.
baer - pad bedding
it looks like i'm going to drive around for at least a month normally, then season rotors over a long weekend, then probably wait till the next weekend and bed in the pads
Old Feb 2, 2012 | 01:48 PM
361 accord's Avatar
Bleeding the brakes requires a properly sized box wrench for the bleeder and the clear plastic bleed hose provided with your system. Good quality, non-silicone fluid is also a must. Baer Brakes has tested a wide variety of fluids and strongly recommends Performance Friction’s Z-Rated fluid #90016 for street and occasional track use (with Motorcraft PM1 our backup suggestion for this same duty). These two have been proven to be more effective than fluids that are often many times more expensive. For racing, Baer recommends and uses only Castrol SRF. Baer stocks and sells both the Performance Friction Z-Rated and Castrol SRF.
Always remember, good to excellent brakes or fluid do not function without adequate cooling. In fact, the more serious your brake system, the more attention that needs to be directed to proper ducting, as they will generate more heat due to increased capacity.
BLEEDING BRAKES IS NOT DONE WITH PRESSURE, IT IS PURELY A FUNCTION OF MOVING FLUID THROUGH THE SYSTEM. THE OBJECT IS TO DISPLACE AIR, NOT TO SEE HOW FAR FLUID CAN BE SHOT OUT OF THE CALIPER!
Proper Bleeding Technique
Enlist someone who will help you bleed the brakes. Make sure they also read these instructions carefully (so they understand the goal).
1.For systems which are essentially dry front and rear, start by filling the master cylinder with proper fluid. Pour slowly so as not to aerate the fluid.
2.Next, move to the first caliper, attach the clear plastic bleed hose to the bleeder and open it. Hold the hose upright so that you can monitor the escape of air bubbles. VERY SLOWLY stroke the brake pedal by hand or foot until fluid comes out. Now close the bleeder.
3.ACTUAL BLEEDING SEQUENCE:
◦Have your partner very slowly, with modest pressure (approximately 25-30 lbs.ft.), stroke the pedal ONE TIME until hydraulic resistance is encountered. Ask your partner to hold at this point with the same modest and even pressure and notify you that he is “holding.”
◦Open the bleeder, letting the pedal go to the floor or until it stops, using the same modest level of pressure, then close the bleeder again
. Notify your partner “the system is sealed.” He can then slowly release pedal pressure.
4.Repeat the BLEEDING SEQUENCE (never stroke the pedal more than one time) until all signs of air are purged (no bubbles) from fluid. IMPORTANT
◦NOTE: DO NOT LET THE MASTER CYLINDER RUN DRY! Be sure to check the fluid level after every third bleeding sequence or sooner if reservoir volume is very small.
5.Before moving to the next caliper, take a small block of wood or a plastic hammer and carefully tap the caliper to dislodge any additional air bubbles that may be trapped. Then bleed one last time.
6.Move to the next caliper and repeat the procedures previously outlined. Continue until all calipers have been bled.
Before re-installing wheels and placing the car on the ground, we recommend you carefully wipe clean all caliper surfaces, hose joints and fittings, making sure they are all dry and free from seepage. If not, inspect and tighten appropriately. Spray all rotor surfaces with Brake KleenŽ or a similar product to remove all dirt and oils from your hands that may have been transferred to the rotor during assembly. Also remember to remove the nut that has been holding rotor in place before attempting to re-install the wheel.
For street use, as with any time you open the brake system, it may be advisable to repeat the bleeding procedure after driving the vehicle for a day, as driving the car may dislodge some additional air bubbles. For competition cars, we recommend repeating this procedure directly after at least the first two sessions the car is on track and at the beginning of each race weekend thereafter.
Even if your pedal is high and firm and additional bleeding is deemed unnecessary, always inspect the calipers, hoses and fittings after the first outing for signs of any fluid seepage and correct immediately.
baer brake bleeding
hmm, i never heard of only one stroke at a time, but that sounds good
still doesnt tell me chit about the what order to do it on my accord (4 disc ABS)
shad295
Honda Civic (2006 - 2015)
16
Nov 4, 2008 03:11 PM
proudcss
Honda Civic (2001 - 2005)
Dec 27, 2007 07:42 AM
Flite
Dec 7, 2006 07:59 AM
jjaskula1
Dec 25, 2005 07:59 AM
