Is this worth it????
Old Apr 28, 2006 | 05:30 PM
G2 Speed's Avatar
Default Is this worth it????
Thinking about getting a sub and the flyers just came today....
Prices are in Canadian , it's worth it?
Old Apr 28, 2006 | 05:49 PM
mrdeadman's Avatar
They let me pick
Default Re: Is this worth it???? (G2 Speed)
just make sure they are the dual voice coil reference subs and make sure the amp is stable at 2ohms while pushing 250-300 watts. those are 250 rms subs.
Old Apr 28, 2006 | 06:47 PM
G2 Speed's Avatar
Default Re: Is this worth it???? (mrdeadman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">just make sure they are the dual voice coil reference subs and make sure the amp is stable at 2ohms while pushing 250-300 watts. those are 250 rms subs.</TD></TR></TABLE>
and if it is dual voice coil, then it's worth it?
edit:
The Infinity 10" Subwoofer (1040W) features high-efficiency polypropylene woofer cones giving you an hgh output with modest amplifier power. The proprietary deep-draw I-beam basket allows room for a longer motor structure, which provides increased bass output. This basket is also more rigid and has a lower basket resonance. More Info
WebID: 10063257
Mfr. Part Number: 1040W
Band Pass Volume No
Basket Material Proprietary Deep-Draw I-Beam
Binding Posts No
Cone Material Polypropylene
Frequency Response 25Hz - 400Hz
Impedance 4 Ohms
Magnet Weight No
Mounting Depth Info Not Available
Ported Box Volume No
Power Handling Max 250 Watts RMS
Power Handling Nominal 250 Watts
Product Warranty 1 Year Parts & Labour
Recommended For Band Pass Info Not Available
Recommended For Ported No
Recommended For Sealed Info Not Available
Sealed Box Volume No
Sensitivity 91dB
Surround Material Large Roll Rubber
Voice Coil Size Info Not Available
Woofer Size 10"
edit 2:
roduct Details
Web Code: 10063637
Mfr. Part Number: GTO301.1II
# Of Channels 1
1 OHM Output Power - Full Range Info Not Available
14.4V Dynamic Power At 2 Ohms 320 Watts
2 OHM Output Power - Full Range 320 Watts
4 OHM Output Power - Full Range 204 Watts
Bass Boost Yes
Bridgeable Yes
Bridged Power At 2 OHMS - Full Range 294 Watts
Bridged Power At 4 OHMS - Full Range 204 Watts
External Bass Control Capable Yes
Fuse Rating (Amps) 30 Amps
High Pass Filter No
Included In Box Amp, Instruction Manual
Input Voltage 4.7 Volts
Low Pass Filter No
Mosfet Switching Yes
Overload Protection Yes
Product Dimensions 31.27(W) x 6.03(H) x 29.54(D) cm
Product Weight 5.55 kg
Protection Indicator Yes
RCA Inputs (#Pairs) 2
RCA Outputs (#Pairs) 2
Screw Type Terminals No
Signal to Noise Ratio 77 dBA
Smart Engage Turn-On Yes
Speaker LVL Inputs No
Total Max Power 320 Watts
Tri-Mode Capable No
it also comes with
Stinger Amplifier Kit (SWK10R)
This kit for amplifiers can handle up to 300 watts. It features 20' of 10 ga. custom pro red power wire, 3' of 10 ga. custom pro black ground wire, 1 pre-assembled waterproof ATC fuse holder with an 30 amp ATC fuse.
FEATURES:
* 17' Drone Audio Interconnect
* 5' Of Protective Wire Tubing
* 17' Of 18 Ga. Amplifier Remote Turn-On Wire
* 10 x 4" Wire Ties,
* Full Assortment Of 24kt Gold Plated Terminals & Hardware
* Protective, Snap-In Wire Grommet
good, bad.. yes or no?
Thanks
Old Apr 28, 2006 | 08:44 PM
mrdeadman's Avatar
They let me pick
im pretty sure it is just a single voice coil, i would try and get the dual voice coil subs though if i were you, that would match to the amp nicely. if it is a svc (single voice coil) then you need an amp stable at 4 ohms and pushing 250-300 watts rms. dvc (dual voice coil) subs are worth it because you can wire them a couple of ways so you have more amp choices, they go for about 100 a piece here in the us without the box, but sometimes there are buy one get one free sales. i have a 12 inch infinity dvc reference sub and i love it to infinity. 10's sound really good as well. i should have bought the 10. as long as you match the sub specs to the amps then you should be fine.
Old Apr 29, 2006 | 05:20 AM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure it is just a single voice coil, i would try and get the dual voice coil subs though if i were you, that would match to the amp nicely. if it is a svc (single voice coil) then you need an amp stable at 4 ohms and pushing 250-300 watts rms. dvc (dual voice coil) subs are worth it because you can wire them a couple of ways so you have more amp choices, they go for about 100 a piece here in the us without the box, but sometimes there are buy one get one free sales. i have a 12 inch infinity dvc reference sub and i love it to infinity. 10's sound really good as well. i should have bought the 10. as long as you match the sub specs to the amps then you should be fine. </TD></TR></TABLE>
alright thanks for the response, so basically I should look for a DVC....
Old Apr 29, 2006 | 05:30 AM
mrdeadman's Avatar
They let me pick
well if you can find an amp that matches nicely to the svc then you can get the svc, you should not buy the setup you listed though. i don't think there is any sound difference between dvc and svc.
Modified by mrdeadman at 11:24 AM 4/29/2006
Old Apr 29, 2006 | 10:02 AM
G2 Speed's Avatar
Alright, Well i'm going out today to browse and see what there is out there for me, I just want something to give me some bass, my speakers can only give so much...
Old Apr 29, 2006 | 11:10 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">Thinking about getting a sub and the flyers just came today....
Prices are in Canadian , it's worth it?</TD></TR></TABLE> Pricing is OK but it is really the wrong amp for that sub, [about 50W short]. IMO a 300W amp would be better, even a 250W, [better to be over-powered then under-powered]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">just make sure they are the dual voice coil reference subs and make sure the amp is stable at 2ohms while pushing 250-300 watts. those are 250 rms subs.</TD></TR></TABLE> What would be accomplished with a DVC sub?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">and if it is dual voice coil, then it's worth it?</TD></TR></TABLE> For the sub yes, but it's not a DVC, it is a SVC 4 ohm 250W continues, [RMS] power handling 10" sub, that works best is a sealed box with a gross interior volume of .75 cuft., the sub and box are still worth it if the box is within 10% (+/-) of .75 cuft.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">well if you can find an amp that matches nicely to the svc then you can get the svc, you should not buy the setup you listed though. i don't think there is any sound difference between dvc and svc.
Modified by mrdeadman at 11:24 AM 4/29/2006</TD></TR></TABLE> Ditto that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Speed &raquo;</TD></TR><TR><TD CLASS="quote">Alright, Well i'm going out today to browse and see what there is out there for me, I just want something to give me some bass, my speakers can only give so much...</TD></TR></TABLE> If the box is OK, get the sub, just find a mono block sub amp that puts out at least 1x250W RMS into a 4 ohm load. As I said 300W would be better IMO. 94
Old Apr 29, 2006 | 11:57 AM
Concept Tuning's Avatar
Default Re: Is this worth it???? (fcm)
I agree with FCM. The sub would be nice. I have a Rockford Fosgate 900watt max, 300 watt RMS amp for sale if your interested. Has the extended 4 year warranty on it too. PM me if your interested.
Old Apr 29, 2006 | 04:28 PM
mrdeadman's Avatar
They let me pick
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
the dual voice coil infinity reference you can wire to 2 ohms thus making it match the amp.
Old Apr 29, 2006 | 06:39 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">the dual voice coil infinity reference you can wire to 2 ohms thus making it match the amp.</TD></TR></TABLE>
bah.. i'm confused..
Alright... Maybe you can help me find a good system for my needs... I mainly listen to trance, I just need a little extra kick.. I geuss if needed I drive a 96 Civic Si coupe...
Currently I have ...
For my Deck
JVC KD-G510
* Power Output: 200W Max. (50W x 4)
* MOS-FET Power Amp
* SIRIUS Ready
* 24-bit Resolution Burr-Brown 1-bit DAC
* HS-II Tuner
* MP3/WMA Compatible with ID3/WMA Tag
* CD/CD-R/CD-RW Compatible
* cEQ
* Line Output Terminals
* Selectable Front or Subwoofer Output Terminals
* Front AUX Input
* Multi-Color Display
* Rotary Encoder Multi-Control
* Flip-Down Face
My Speakers
JBL CS396
Size 6" x 9"
Type Triax
Power Handling, Peak 210W
Power Handling, RMS 70W
Impedance 4 ohms
Sensitivity (2.83V/1m) 91dB
Frequency Response 50Hz - 20kHz
JBL CS206
Size 130mm
Type Coax
Power Handling, Peak 90W
Power Handling, RMS 30W
Impedance 4 ohms
Frequency Response 70Hz - 20kHz
What should I get for a sub and amp?
Looking to spend under $400 Canadian
Thanks, Alot
Old Apr 29, 2006 | 07:47 PM
mrdeadman's Avatar
They let me pick
i would stick with that infinity 10 inch sub with the sealed box and find an amp that puts out 250-300 watts rms into 4 ohms.
Old Apr 29, 2006 | 08:28 PM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">i would stick with that infinity 10 inch sub with the sealed box and find an amp that puts out 250-300 watts rms into 4 ohms.</TD></TR></TABLE>
alright well looks like at least I could have the sub.. I mean it seems like a pretty good deal, all wait for fcm to respond also
Old Apr 29, 2006 | 10:00 PM
Barfdogg's Avatar
You may want to look into getting a ported box too...
Old Apr 30, 2006 | 11:37 AM
fcm's Avatar
fcm
Old Fart
the dual voice coil infinity reference you can wire to 2 ohms thus making it match the amp.</TD></TR></TABLE> OIC what you mean, I thought you ment it would be a deal if it was a DVC, but yes you are correct, the amp is 1x294W RMS into 2 ohms.
alright well looks like at least I could have the sub.. I mean it seems like a pretty good deal, all wait for fcm to respond also </TD></TR></TABLE> I agree with mrdeadman on that, keep/get the sub and just find an amp, or get/keep the amp and get the DVC 4 ohm sub, ask at the store that is selling the stuff if they would give you the same deal on the DVC sub. 94
lickety_britches
Audio / Security / Video
Dec 18, 2007 02:46 PM
nylshatch
25
Feb 16, 2007 03:33 PM
teknoracing
30
Jun 7, 2006 03:42 PM
kitkat77
17
Aug 20, 2003 05:34 PM
Itz Darave
17
Jul 19, 2003 01:30 PM
