wiring sidemarkers
Old May 12, 2007 | 06:02 PM
kleen98accord's Avatar
Default wiring sidemarkers
How do i go about wiring my sidemarkers if i want them to turn on when i just turn on my parking lights? (one click on the head light switch). But at the same time i dont want them blinking when my turn signal is blinking.
Old May 12, 2007 | 06:44 PM
DC5_lov3r's Avatar
I think you need to tap into the red just for the parking lights.
Old May 12, 2007 | 07:45 PM
fcm's Avatar
fcm
Old Fart
Default Re: wiring sidemarkers (randomvtec)
Plug them into the park light free pin on the under dash fuse box. 94
Old May 12, 2007 | 09:31 PM
Default Re: wiring sidemarkers (fcm)
hmm. can you give me some more details. or can i just splice into the headlight wire?
Old May 13, 2007 | 06:06 AM
fcm's Avatar
fcm
Old Fart
Your under dash fuse box has a set of "free pins", one of them is the park light circuit, there is also a constant 12V+ and a 2nd ign. free pin.
They are there for adding power circuits to your car so use them, an in-line fuse should be installed close to the free pin. 94
Modified by fcm at 8:38 PM 5/14/2007
Old May 14, 2007 | 06:46 PM
could i just splice the side marker wire into the headlight wire. then ground it? its easier
Old May 14, 2007 | 07:31 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
What Kind of car is it?
Old May 14, 2007 | 08:47 PM
Default Re: wiring sidemarkers (wrx-killer-Sti eater)
98 honda accord coupe
Old May 14, 2007 | 09:36 PM
The way I do them is to shoot the wire thru the sub fram arm up to the turn signal, Tag it to the red/black. Do it for both sides. The red/blk does not blink. There should be a dual element bulb. One the parking light the other is the blinker. Its easier or yo can do it fcm way. That will work too.
Old May 16, 2007 | 01:40 PM
thanks
89 ed6 FTW!
23
Jan 16, 2011 09:24 AM
itsJDMyo
Audio / Security / Video
13
Jun 29, 2009 04:53 PM
lYellowDragonl
Mar 7, 2005 06:54 AM
EJ8 GSR-T
Sep 16, 2004 07:31 PM
S13 slide
Jan 20, 2002 10:35 PM
