Wiring of Amp
Old Jan 4, 2002 | 09:46 AM
TexTeg's Avatar
Default Wiring of Amp
I am running one 12" sub off a 175x2 amp. I was wondering if I can bridge the two channels together by running positive from one channel and negative from the other channel to achieve 350x1 at whatever impedence it is rated at?
Old Jan 4, 2002 | 11:00 AM
Daemione's Avatar
Default Re: Wiring of Amp (TexTeg)
Yeah, you can. Check the manual to find out which pos & neg to use, and what load it'll be stable at when bridged.
Old Jan 4, 2002 | 11:50 AM
Mista Bone's Avatar
D Tranny Guru
Depends on the sub and amp.
Any GOOD amp and a 4 ohm sub will be happy.
Old Jan 4, 2002 | 09:38 PM
GSRaCeRbOI's Avatar
Default Re: Wiring of Amp (Mista Bone)
it depends on your amp.. it should be able to be bridged tho..check your manual or look at the amp itself.. sometimes you can see which leads you need to use on the amp when its bridged and when not (it might be labeled like on my amp)
VTECth1s
Audio / Security / Video
23
May 26, 2011 12:10 PM
Liquidgsr
15
Jan 24, 2007 12:12 PM
Mazzazx51
May 19, 2004 05:55 AM
GroundZer0 336
20
Aug 30, 2003 04:27 AM
redteg1
Apr 9, 2002 08:46 PM
