Will it handle the load?
OK I'm getting Ps2 and and a 7"monitor in my car as a christmas present to myslef! LOL Anyway, I'm getting the "on dash" monitor with cigarette plug power up, Also my Ps2 is going to work thru the power invertor that is ALSO going to be sucking the power from the cigarette plug. So its like 2 in 1, Monitor and PS2 from the cigarrette plug. I wont blow any fuses wont I? It seems like its a huge power load. Will it handle? THanks
Whenever I add an accessory that is going to pull a fair amount of current I hardwire to the battery. This way I can leave the stock wire alone. Just make sure you put an inline fuse near the battery.
Guys new problem! I got the monitor in mail today and I discovered that it had 3 RCA outputs MALE connectors, which means i can hook it up to the female connectors that are on the DVD's VCR's etc.... however I dont want to... I want to have my PS2 to be hooked up to my monitor. Problem is... PS2 is also and "OUT" male type of RCA connector that usually plugs in the home TV's So how can I connect two OUTS together? Does it mean I cant hook my ps2 to the tv monitor?
Please help!
Please help!
check you local radio shack i thik i remeber seeing conncetors that change you outputs to whatever you need them to be male femaleand soforth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZexyAccord »</TD></TR><TR><TD CLASS="quote">What about the RCA? post... read above?</TD></TR></TABLE>I think you are missing a part, if all you have is the screen, you will need a vidio processor
94
94
ketchup
29
Mar 27, 2009 09:33 AM
niceprelude
Dec 24, 2008 07:13 PM
