Will this fuel kill setup work?
Old Apr 11, 2007 | 09:21 AM
JLEK's Avatar
Default Will this fuel kill switches setup work?
I'm trying to add a switch to my current fuel kill setup.. I was wondering if adding a switch between the relay and the current switch will work? how many amps are running thru the wire between the switch and relay? im working on a 96ek
Thanks in advance.
Modified by emperor9 at 5:31 PM 4/11/2007
Old Apr 11, 2007 | 04:29 PM
JLEK's Avatar
Default Re: Will this fuel kill setup work? (emperor9)
please chime in...
Old Apr 11, 2007 | 04:36 PM
fcm's Avatar
fcm
Old Fart
Default Re: Will this fuel kill switches setup work? (emperor9)
There is less then a 250mA load on that lead, it only controls the relay. 94
Old Apr 11, 2007 | 04:39 PM
JLEK's Avatar
Default Re: Will this fuel kill switches setup work? (fcm)
fcm- will this setup work?
Old Apr 11, 2007 | 05:02 PM
94_DC4's Avatar
Yes. The setup you have shown will work.
Old Apr 11, 2007 | 10:46 PM
suspendedHatch's Avatar
Why did you add a second switch?
Old Apr 12, 2007 | 11:43 AM
JLEK's Avatar
Default Re: Will this fuel kill switches setup work? (suspendedHatch)
i would think a second switch will make it that much harder if a thief got lucky and found the first one.
Old Apr 12, 2007 | 01:25 PM
CivicSD's Avatar
DUDE JUST ADD SOME toggle switches, why the hell are you introducing a relay???
Old Apr 12, 2007 | 02:19 PM
94_DC4's Avatar
If you want to use two switches then I would recommend that they each have their own lead going to the relay.
Old Apr 12, 2007 | 02:52 PM
JLEK's Avatar
Default Re: Will this fuel kill switches setup work? (94_DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_DC4 &raquo;</TD></TR><TR><TD CLASS="quote">If you want to use two switches then I would recommend that they each have their own lead going to the relay.</TD></TR></TABLE>
94_dc4-
i might be misunderstanding and often i do, im im wrong i would like to be set correct. i want two switches both to be switch on for the fuel pump to come on. wouldn't having two switches to ground the relay defeat the purpose of having two switches?
thanks for help,
Jon
Old Apr 12, 2007 | 02:53 PM
JLEK's Avatar
Default Re: Will this fuel kill switches setup work? (CivicSD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicSD &raquo;</TD></TR><TR><TD CLASS="quote">DUDE JUST ADD SOME toggle switches, why the hell are you introducing a relay???
because i am extending beyond 5 feets of wires and wish to make sure that the fuel pump isnt starving for more power...
Old Apr 12, 2007 | 03:05 PM
94_DC4's Avatar
emporor9- Yes you are right. Having two switches will defeat the purpose. I didn't pay close enough attention the diagram. If you set it up as normally closed then it would make more sense having two swithches.
Old Apr 12, 2007 | 04:12 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emperor9 &raquo;</TD></TR><TR><TD CLASS="quote">
because i am extending beyond 5 feets of wires and wish to make sure that the fuel pump isnt starving for more power... </TD></TR></TABLE> Remove the relay and the wiring install a small 1A switch on the black lead going to PGM-FI Main Relay, it will cut your fuel injectors, some sensors, one of the powers to the ECU/ECM and the fuel pump, it's a low current ground for the injector relays coil.
And if you want to double up install a switch on the ECU/ECM control lead to the fuel pump relay, also a low current ground, no 12V+ to deal with at all, no relays, and very little wiring. 94
Old Apr 12, 2007 | 04:43 PM
JLEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Remove the relay and the wiring install a small 1A switch on the black lead going to PGM-FI Main Relay, it will cut your fuel injectors, some sensors, one of the powers to the ECU/ECM and the fuel pump, it's a low current ground for the injector relays coil.
And if you want to double up install a switch on the ECU/ECM control lead to the fuel pump relay, also a low current ground, no 12V+ to deal with at all, no relays, and very little wiring. 94</TD></TR></TABLE>
fcm- where is the pgm-fi main relay located at? what lead is the power lead to that so i can use the ground next to it like you said.. will doing this cut power to ecu so that everytime i turn the 1a switch off the ecu is basically being reset? im really interested in main relay kill switch. im just going off suspendedhatch stickie on how to provide better anti-thief protection for our hondas.
thank you all for your input.
Old Apr 12, 2007 | 04:50 PM
You might want to mention your year/make/model before you go asking where certain things are located. Or you can ask a pyschic...
fcm's been telling people this for years. I guess it's time for me to do a write-up "pikturs, yay!!"
Old Apr 12, 2007 | 05:08 PM
JLEK's Avatar
sorry.. i need to add below that its for a 96EK sorry... i had it on my original post. thanks.
write up for the main relay would be awesome.. LOL go suspendedHatch!
Old Apr 13, 2007 | 05:59 AM
fcm's Avatar
fcm
Old Fart
The PGM-FI Main Relay is located 4-5 inches directly above the hood release on 88-91 Civics, there is only one black lead, and the ECU/ECM lead is green/yellow.
It is a normally switched power to the ECU/ECM, so it does not reset ECU/ECM. 94
thundernoodle
Audio / Security / Video
15
Aug 6, 2010 06:05 AM
socalrex88
Mar 2, 2008 01:50 PM
JLEK
May 10, 2007 10:40 PM
TurboTurtleGSR
Jan 17, 2003 09:04 PM
RCautoworks
Dec 30, 2002 01:51 PM
