Will This AMP power this SUB efficiently...?
Old Dec 11, 2004 | 11:08 PM
DIYaccord's Avatar
Default Will This AMP power this SUB efficiently...?
I work for Radioshack and can get a great deal on these components:
http://www.pioneerelectronics....onent
Pioneer Ported Box with 12" 400watt sub (TS-WX121)
and
Pioneer GM-X374 400watt 4ch amplifier
I was thinking just using the amp just for the sub and bridging it
...but might use the amp for the fronts and the sub.
What do you think?
Modified by DIYaccord at 11:18 AM 12/12/2004
Old Dec 12, 2004 | 08:57 AM
fcm's Avatar
fcm
Old Fart
Default Re: Will This AMP power this SUB efficiently...? (DIYaccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">I work for Radioshack and can get a great deal on these components:
and
What do you think?</TD></TR></TABLE> First you can't bridge a 4ch amp into a monoblock, [ one channel] so just useing it just for the sub would leave you with 2 unused so the best would be 2 channels to run the front speakers , [high-pass] and bridge the other two for the sub, that said, you will only have 100watts for the sub, [looking at the specs, that looks more like 70 watts ] although that will work, it is a little low for sub bass, [takes a fair amount of power, (watts) to make good sub bass. One more thing, in its bridged mode, the amp is not stable below 4OHMs and I did not see the imp. speck for the sub, but I would think its a 4OHM SVC.
They say........
1- Golden ratio.... 3 times the watts for sub bass as the rest of the system
2- A truism...... you are better off to be overpowered then underpowered
94
Old Dec 12, 2004 | 10:15 AM
DIYaccord's Avatar
Can you hurt anything by underpowering?
How about this amp? (I'm plenty used to hooking this stuff up, but not really sure on how to pick stuff out)
http://www.pioneerelectronics....html
Old Dec 12, 2004 | 10:57 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIYaccord &raquo;</TD></TR><TR><TD CLASS="quote">Can you hurt anything by underpowering?
</TD></TR></TABLE>Yes, its a lot easier to blow a speaker when you are underpowered, its hard to hear the amp "clipping", very hard an sub bass, that said, putting all 400 watts of power into a 100 watt speaker will also blow the speaker, but when you overpower a speaker you know it right away, [over excution] but you can turn gain on amp down 94
Old Dec 12, 2004 | 11:00 AM
fcm's Avatar
fcm
Old Fart
</TD></TR></TABLE> Again, only stable to 4OEMs bridged and only 2ch but a much better amp for sub bass 94
Old Dec 12, 2004 | 11:27 AM
DIYaccord's Avatar
Default Re: Will This AMP power this SUB efficiently...? (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Again, only stable to 4OEMs bridged and only 2ch but a much better amp for sub bass 94</TD></TR></TABLE>
What's that mean? only stable to 4oems bridged? and what's SVC and DVC?
thanks
Modified by DIYaccord at 1:11 PM 12/12/2004
Old Dec 12, 2004 | 05:13 PM
fcm's Avatar
fcm
Old Fart
thanks
Modified by DIYaccord at 1:11 PM 12/12/2004</TD></TR></TABLE>Sorry SVC= single voice coil, DVC= dual voice coil.
Only stable to 4 ohms bridged. means the amp does not like to see less then 4 ohms when it is bridged, it will overheat and can be damaged, so if you have a 4 ohm DVC sub, and the coils are wired in parallel, you end up with a 2 ohm load most amps, when you bridge them will need at least a 4 ohm load, evan though they will work with a 2 ohm load in the 2ch mode, and both the amps you show are not stable at 2 ohms when bridged. 94
sumdewd
Audio / Security / Video
May 17, 2012 05:22 PM
TANKE92113
12
Feb 6, 2007 01:59 PM
VietFoo
Oct 21, 2005 11:52 AM
.David
Apr 16, 2005 04:20 PM
jaM3s Bond
Jul 17, 2004 12:31 AM
