where to run wire...
Old Sep 22, 2002 | 08:11 AM
civicmark's Avatar
Default where to run wire...
ok, i'm wondering where the best place to run a single wire from mr dash, into the engine bay would be? I'm putting in an alarm, and i need to run a wire out to the horn.
thanks
edit: it's in a 92 civic dx
[Modified by civicmark, 5:13 PM 9/22/2002]
Old Sep 22, 2002 | 09:12 AM
GSRaCeRbOI's Avatar
Default Re: where to run wire... (civicmark)
theres hella places along the firewall.. just look for those black plugs/grommets and whichever is closest to whatever your installing would be the easiest... you could always just drill a new hole and get a rubber grommet and run the wire there....
Old Sep 22, 2002 | 09:26 AM
civicmark's Avatar
Default Re: where to run wire... (GSRaCeRbOI)
thanks, i found one that i'll use. now my second question is: Where is the best place to mount the horn?
thanks
Old Sep 22, 2002 | 09:32 AM
GSRaCeRbOI's Avatar
by horn you mean alarm siren? or are you putting in air horns in addition to your alarm siren?
anyway for the alarm siren.. you can put it in the fenderwell, or like under the stock air box... you can also put it behind the intake manifold between the IM/throttle body and firewall... but then its pretty easy to see/accessible and easy to cut the wires..
Old Sep 22, 2002 | 11:25 AM
civicmark's Avatar
sorry, but i did mean siren. i think i'll put it in the fender well though
chillerice
Audio / Security / Video
Apr 30, 2013 07:54 PM
r22thomas
Aug 15, 2010 08:42 AM
funtak
Sep 12, 2007 04:51 PM
91civichatch
Apr 27, 2006 09:01 PM
litterbox
12
May 27, 2004 05:17 AM
