where to ground a HU?
Old Apr 12, 2007 | 08:01 AM
ekferio's Avatar
Default where to ground a HU?
i got the annoying alternator whine after putting in the Pioneer D3, pulled the ground wire out of the harness and attached it to the bolt inside the dash but no help. I have a RSX with factory bose amp (no rca cables) & sub. Also when i unplugged the preamp rca cables, the noise disappeared. I want to try moving the ground to a different spot but not sure where?
Old Apr 12, 2007 | 08:30 AM
B18C_EJ8's Avatar
Try directly to the neg terminal on the battery.
Or a good chassis ground, not a secondary ground to metal in the dash.
Old Apr 14, 2007 | 07:01 AM
LudemanDan's Avatar
Yep, I wouldn't even use the metal pillars that bolt to the chassis and hold the dash up. Just drill a hole in the nearest part of the chassis itself, run a wire down to there with a ring terminal on it, screw it down and you're good.
Old Apr 14, 2007 | 09:00 AM
fcm's Avatar
fcm
Old Fart
Default Re: where to ground a HU? (ekferio)
What are you using as an interface between the Pioneer HU and the Bose system? 94
Old Apr 14, 2007 | 05:20 PM
regal1975's Avatar
Default Re: where to ground a HU? (fcm)
i would look as mentioned before at the cables that connect to the bose unit.. likely pinched or run near a source of noise...
MilanoRedDashR
Audio / Security / Video
15
Jul 3, 2009 05:44 AM
DuniCraig
Aug 11, 2008 01:09 AM
vinuneuro
Sep 11, 2007 11:29 AM
3ni_stylez
Jul 13, 2006 08:41 AM
h22accordr
Jun 29, 2004 11:27 AM
