Where do you install the small crossovers ??
Old Feb 27, 2002 | 09:13 AM
99_SH's Avatar
Default Where do you install the small crossovers ??
I'm finally gonna purchase the Infinity kappa 60.3cs. They come with a small crossover box. Do you guys usually install this in the door? thats what I'm planning on doing
btw, this is for a 97 civic coupe
someone posted before how to change the rear speakers. I cant find the post anymore could one of you guys please retype it? It involved removed many parts to remove the rear deck.
thanks!!!
Old Feb 27, 2002 | 12:08 PM
nsxxtreme's Avatar
Default Re: Where do you install the small crossovers ?? (99_SH)
If you install it in the door rap it in plastic or something else to keep the water out.
Yes water gets inside the door.
Old Feb 27, 2002 | 01:55 PM
GSRaCeRbOI's Avatar
i put mine in the doors laying flat and put it in a bag and zip tied it...
try these links
https://honda-tech.com/zerothread?id=39544 https://honda-tech.com/zerothread?id=48832
[Modified by GSRaCeRbOI, 10:56 PM 2/27/2002]
Old Feb 27, 2002 | 05:41 PM
CanadaCivicSIR's Avatar
New User
Default Re: Where do you install the small crossovers ?? (GSRaCeRbOI)
If you remove the door there is a little pocket under the handle, I hot glued mine there, it keeps it out of the moisture.
Old Feb 27, 2002 | 06:24 PM
nsxxtreme's Avatar
Default Re: Where do you install the small crossovers ?? (CanadaCivicSIR)
This is a good Idea it just depends on the car if you have space. This is where I put mine on the NSX.
Old Feb 28, 2002 | 10:02 AM
Stephen's Avatar
Default Re: Where do you install the small crossovers ?? (nsxxtreme)
I put them in little bags as well and taped them inside the door. Seems to be what most people do.
Old Feb 28, 2002 | 03:59 PM
ThePunk's Avatar
Default Re: Where do you install the small crossovers ?? (Stephen)
Epoxy them to the back of the door panel. (That way they don't get wet.) Just make sure there's enough room for it to fit, and be able to reinstall the panel. (BEFORE you glue it on)...
spintboy
Dec 29, 2006 02:50 PM
chris3k
Audio / Security / Video
Feb 7, 2006 02:51 PM
sykotic
Jan 3, 2006 08:51 PM
acuraLSSE95
Jan 1, 2002 08:00 PM
vpforeva
Oct 4, 2001 03:29 PM
