What wires are needed?
Old May 26, 2005 | 09:09 AM
honda95civic's Avatar
Default What wires are needed?
What wires are needed for power windows
Im shaving my handles.. and dont need the door lock wires.. because they dont work anyway..
I want to have the least amount of wires through the door for a clean look.
so power and grounds for windows and door popers is all i need and speakers
dont need nething related to the door locks thankyou
95 civic ex power everything..except mirrors
Old May 26, 2005 | 09:34 AM
fcm's Avatar
fcm
Old Fart
Default Re: What wires are needed? (honda95civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic &raquo;</TD></TR><TR><TD CLASS="quote">What wires are needed for power windows
95 civic ex power everything..except mirrors</TD></TR></TABLE>Not sure what you mean, "what wires needed for power windows". What do you want to do with the power windows? or are you adding power windows? And because you are shaving your door handles, you don't need door locks, So I would remove the actuators, and then you have some wires going into the door that can be used for something else. So all you need is a good power and ground, [14ga or 12ga] you can install the relays for the "door popers" inside the doors and use the door lock wires, [one of them] to trigger the relays, 94
Old May 26, 2005 | 10:13 AM
Default Re: What wires are needed? (fcm)
Like i said.. i have power everything.. want to get rid of unnessasary wires.. such as door locks..
all i need is the wires for windows.. power wiring for mirror turn signal, speakers.. and door poppers..
want to get rid of power door lock wires..if i can
Old May 26, 2005 | 10:46 AM
o_O's Avatar
o_O
hope you can read this......(taken from http://www.the12volt.com )
1995 Honda Civic Security Information
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel Blue Connector
Parking Lights Red/Black Fuse Panel or Driver's Kick Panel
Head Lamp Red/White Steering Column
Hood Pin n/a
Door Trigger Light Green/Red (-) Driver's Running Board One of Two Wires
Door Lock Green/White (-) 2 Pin Connector TapeD to Blue Connector behind Fuse Panel
Door Unlock Green/Red (-)
Horn Wire Blue (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
Old May 27, 2005 | 06:35 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic &raquo;</TD></TR><TR><TD CLASS="quote">Like i said.. i have power everything.. want to get rid of unnessasary wires.. such as door locks..
want to get rid of power door lock wires..if i can</TD></TR></TABLE>OIC... So all you need to do is remove the 2 wires for the doorlocks, but you will still need to add a power and ground for the "door popper", [solinoid] I would leave the doorlock wires in place and use them to trigger the relay for the solinoid, [that you install in the door] 94
Old May 27, 2005 | 08:22 AM
i bought the car off this guy who had a viper alarm and the door locks didnt work. I didnt find out until one day i opened the door and the alarm went off. So i pressed the lock/unlock button.. nothin happened.. took off the door panel and the wiring was a mess. the door locks didnt get power.. so i ran new wires from the brain.. i got them to lock.. but they wont unlock.. seems like they try but they get stuck.. so i dont want to deal with it. thats y im shavin the handles.
Old May 27, 2005 | 03:32 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda95civic &raquo;</TD></TR><TR><TD CLASS="quote">i bought the car off this guy who had a viper alarm and the door locks didnt work. I didnt find out until one day i opened the door and the alarm went off. So i pressed the lock/unlock button.. nothin happened.. took off the door panel and the wiring was a mess. the door locks didnt get power.. so i ran new wires from the brain.. i got them to lock.. but they wont unlock.. seems like they try but they get stuck.. so i dont want to deal with it. thats y im shavin the handles. </TD></TR></TABLE>LMAO..... your shaving your door handles because you don't want to deal with the door lock wiring, do you know what a pain door release solenoids, [door poppers] and their wiring can be, Don't get me wrong, I like a car with a clean shave, but to do it just because you think it may be easier. 94
GESEKI
Jan 28, 2013 04:46 AM
96teggynonVtec
Feb 12, 2007 03:31 PM
Ignitecivic
Audio / Security / Video
Mar 28, 2005 08:07 AM
ninja8oi
Mar 23, 2003 03:03 PM
MilanoRex
May 19, 2002 08:53 PM
