What size fuse/wire for battery relocation?
Already searched this a lot... My battery says "cranking amps" = 544 amps. Is that how big an inline fuse in the + wire has to be? That sounds really, really high. Is it okay to run a 4 ga. wire? Is the fuse REALLY necessary? Thanks in advance.
First of all, if you can find a 544 amp fuse, I'll buy it for you...
Second, 4 ga is fine.
Third, yes the fuse is necessary. 60 amp should be sufficient.
civiccoupe94
09-19-2008 01:27 PM
