what do all the channels on a hu do?
Old Jan 1, 2006 | 09:03 AM
mrdeadman's Avatar
They let me pick
Default what do all the channels on a hu do?
what's the difference between a hu with 4 channels and one with 2 or whatever. why do you need more channels?
Old Jan 1, 2006 | 11:32 AM
fcm's Avatar
fcm
Old Fart
Default Re: what do all the channels on a hu do? (mrdeadman)
Each channel drives a speaker, so a 2 ch. will drive a left and right speaker, [front]
a 4 ch. will drive the left and right fronts and a set of rears, [left and right] and with the 4 ch. you can fade between the front and rear speakers. 94
Old Jan 1, 2006 | 06:23 PM
mrdeadman's Avatar
They let me pick
Default Re: what do all the channels on a hu do? (fcm)
my car has 6 speakers. so do i have to get a 6 channel hu? it's a teg '97. thanks.
Old Jan 1, 2006 | 08:08 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
no, you won't need a six channel amp. the front speakers are componets.
Old Jan 2, 2006 | 04:36 AM
mrdeadman's Avatar
They let me pick
Default Re: (wrx-killer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer &raquo;</TD></TR><TR><TD CLASS="quote">no, you won't need a six channel amp. the front speakers are componets. </TD></TR></TABLE>
what does that mean? sorry for amature questions but im new the the hu game.
Old Jan 2, 2006 | 08:44 AM
suspendedHatch's Avatar
Default Re: (mrdeadman)
Your tweeters and woofers are seperate. They're connected by a crossover that divides the frequency sending the highs to the tweeter and the mids and lows to the woofer. At my work they always disconnect the tweeter and replace the woofer with a two way speaker. Unless of course they want to buy replacement components.
Old Jan 2, 2006 | 11:14 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> They're connected by a crossover that divides the frequency sending the highs to the tweeter and the mids and lows to the woofer</TD></TR></TABLE>
Probably not an actual crossover... More likely a capacitor inline to filter out the lows going to the tweeter.... But same idea...
Old Jan 2, 2006 | 01:15 PM
mrdeadman's Avatar
They let me pick
Default Re: (B18C_EJ8)
so in the line of hus what do i need? a 4channel? does it even matter? it all plugs in anyway. right?
Old Jan 2, 2006 | 03:58 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrdeadman &raquo;</TD></TR><TR><TD CLASS="quote">so in the line of hus what do i need? a 4channel? does it even matter? it all plugs in anyway. right?</TD></TR></TABLE>Yes get any HU you want, if your not running amps, look for a "high power" HU, it will say something like 50 watts per ch., most HU will be 4 ch., [I can't think of any that are not] get a Metra harness adpt., [70-1720] so you do not have to cut the oem radio plug off, you will also need a kit, [Metra 99-7892].
Connect the Metra adpt. harness to the HUs wiring harness, it should be color for color, if you get a "true" "high power" HU, [more then 15W RMS per ch.] you will not use the constant power, [yellow] on the Metra adpt. harness, [just yank it out of the plug] you are going to need more power, [amps] so you are going to have to run a 12ga or 10ga fused power wire from the batt. so the HUs internal amp gets enough current, [amps] as it needs more then the oem constant power can supply. 94
Old Jan 2, 2006 | 05:00 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">most HU will be 4 ch., [I can't think of any that are not] </TD></TR></TABLE>
Yeah... I haven't seen a 2 channel HU in years... Even the el cheapo Durabrand ones at Walmart ar 4 channel...
Old Jan 2, 2006 | 05:42 PM
mrdeadman's Avatar
They let me pick
Default Re: (fcm)
last time you said i did not need an install kit, that most aftermarket hu's will fit in the stock location. you said the only thing was that attaching that little box underneath the stock radio to the new hu needed minor modification of brackets. so do i or dont i need an install kit? thanks. and also when running the 10 or 12 gauge power cable how do i go about doing that? sorry for so many questions, im just super interested in this stuff.
Old Jan 2, 2006 | 05:47 PM
fcm's Avatar
fcm
Old Fart
If you are going to use the stock pocket, no you will not need a kit, you will have to do the custom brackets to mount the HU to the pocket, [solidly] and mount both using the back brace support on the HU to the oem rear support brace. 94
Old Jan 2, 2006 | 05:51 PM
mrdeadman's Avatar
They let me pick
Default Re: (fcm)
sweet thanks.
{Powered by VIII}
Audio / Security / Video
27
Jan 15, 2006 09:10 AM
Thanks knightsport!
Aug 8, 2005 07:24 AM
sykotic
Aug 27, 2004 06:49 PM
Unjockable
18
Jul 5, 2004 10:24 AM
ls-t del sol
Dec 16, 2003 02:00 PM
