What Diodes?
Old Dec 15, 2008 | 06:44 AM
The G2 Racer's Avatar
Default What Diodes?
I need to use diodes in my alarm install but in the stickies, it doesn't say what exact kind, just 1-3amp. I'm assuming I want diodes rated for 12V? I'm having trouble finding ones rated for 12V.
Old Dec 15, 2008 | 06:54 AM
Davus's Avatar
Yeah, 12 volt diodes, I just got a bunch of 1 amp diodes, DEI makes some.
I could not find any through stores and dealers and such, so I eBay'd 12 1 amp DEI diodes for about $4.50 shipped. Radio Shack sells diodes, but probably $0.99 each or something.
Old Dec 15, 2008 | 07:02 AM
I've tried a local electronics whole seller and had little luck. I might go back and spend some more time to see if I can find them.
Thanks!
Old Dec 15, 2008 | 09:14 AM
nsxxtreme's Avatar
You wont find 12V diodes, most are rated for 100V or so.
1004 I believe is the general purposed diode from radio shack.
The high voltage rating is the point at which the diode will break down and allow current to flow in the opposite direction. Meaning you fine to use it for voltages below 100V.
Old Dec 16, 2008 | 06:26 AM
HiProfile's Avatar
A car should really never need something above 50 volts, which is the most a 1N4001 can carry. Even at radioshack its $2.79 for a 25-pak. They are 1 amp, but grouping multiples will split the amperage just like any other electrical part.
I'm almost thinking about getting some of the 6 amp diodes, RS has them for $2.49 for 4. Its cheaper than adding another relay to get my rear defogger working with remote start.
cmasonrun
Honda Civic (2006 - 2015)
Sep 21, 2011 06:47 PM
1Point8DC2
Audio / Security / Video
May 8, 2008 12:30 PM
imadigitalgod
Nov 4, 2007 12:53 PM
Mark27
Aug 3, 2006 05:54 PM
Ronin150
May 14, 2004 10:25 AM
