Weird speaker problem?
Old Mar 30, 2006 | 07:49 PM
crxY-49's Avatar
Default Weird speaker problem?
This may be an easy one for you speaker gurus . . .
I just bought a 2000 cx. It only has 2 front speakers. Both have never simultaneoulsy worked. I installed a cd player and the pass side speaker is messed. I know the speakers and cd player are in good shape.
Here is the weird part: if I turn the balance all the way to the left (driver side) the front driver side speaker will work fine.
Then if I try to balance it at 0 (both speakers) they will both become crackling and distored.
Thanks in advance
Old Mar 31, 2006 | 12:37 AM
spooneg8's Avatar
maybe a bad connection...check and see if the clip/wire came disconnected on the speaker...or check to see if theres a nic in the wire and its touching metal..i had the same problem and i found out that a wire was niced and was grounding out under my dash....
Old Mar 31, 2006 | 08:30 AM
crxY-49's Avatar
Default Re: (mysql)
ok thanks . . . im gonna go troubleshoot it again for the millionth time.
Old Mar 31, 2006 | 12:41 PM
fresh pizza guy's Avatar
$4500 in a D series
Default Re: (crxY-49)
one of them could be grounding out..
Manolo
Audio / Security / Video
May 15, 2006 02:25 PM
92-LS-Civic
Oct 7, 2005 09:06 AM
PapaPark
Jul 27, 2005 07:40 AM
AaronJ
Jan 12, 2004 07:48 PM
rad_thundercat
Aug 23, 2002 10:21 PM
