Weird problem
Old Aug 12, 2003 | 01:38 PM
doe's Avatar
doe
Default Weird problem
Okay, here's the deal:
I oftentimes hear a whistling/hissing inside the cabin of my car while driving. It increases as the RPMs increase and decreases accordingly. I thought this was due to my intake, because it happened on my old car (although it's MUCH more pronounced on the Prelude).
Anyway, the other day I turned the VOLUME all the way down on my stereo, and the whistling DISAPPEARED. I am totally confused as to what causes this, but here's a recap:
-whistling noise
-appears related to the RPMs
-disappears when volume on radio is turned to 0 or stereo is off.....
Oh, I have a Pioneer DEH-840MP, if that matters. Any help? I'm baffled.
Old Aug 13, 2003 | 06:07 AM
photec3's Avatar
Default Re: Weird problem (doe)
I could be wrong but I believe that a bad ground is causing it.
Old Aug 13, 2003 | 06:24 AM
pnthr30's Avatar
Default Re: Weird problem (photec3)
What kind of radio / system do you have? I agree, the gounding is more than likely the problem.
Old Aug 13, 2003 | 09:00 AM
Jagan'92's Avatar
Default Re: Weird problem (pnthr30)
engine noise/whine is a bad ground, hence grounding is the problem.
first make sure your amp power is separate from your rca or speaker wires. don't run them next to each other if you can help it.
make sure your amp is grounded well.
also look into those ground loop isolaters. i used some that filter the rca cables, and they didn't work too well. there is a better one available that connects at the battery or alternator. check out jcwhitney and look for noise suppressors.
Modified by Jagan'92 at 1:45 PM 8/13/2003
Old Aug 13, 2003 | 09:32 AM
ATF Kuk's Avatar
its engine noise/whine. its most likely that the power wires and rca's/speaker wires are too close somewhere. make sure u ran the power wires opposite from rca and speakerwires. if it is opposite sides, make sure the wires arent crossing or close to each other when wiring up the amp. check ground too, but i doubt its bad ground
Old Aug 13, 2003 | 10:29 PM
doe's Avatar
doe
Default Re: Weird problem (ATF Kuk)
All I have in my car is the head unit, no aftermarket amp/speakers/woofers.
I'll call my shop tomorrow and ask them if they agree with the opinion here and have them take a look at it. Thanks for the suggestions, everyone.
Old Aug 14, 2003 | 07:50 AM
CivicEKCP's Avatar
It is deffinatly a bad grounding problem. The only other thing I can think of is that I had an old sony deck that was doing the same thing to me and it ended up being a bad head unit. Check grounding first as it is the cheapest route to troubleshooting your problem. Hope you get this fixed that noise drove me insane
em2-matt
Honda Civic (2001 - 2005)
Mar 26, 2010 08:29 AM
pl8rzclub
Audio / Security / Video
Sep 24, 2007 04:04 PM
scrambledeg
10
Dec 9, 2003 07:12 PM
TurboTeG4
Nov 2, 2003 05:59 PM
