Volfenhag subs...
Old Mar 17, 2003 | 05:28 PM
LudeyKrus's Avatar
Default Volfenhag subs...
Can anyone help me find the recommended enclosure sizes for the Volfenhag ZX-4710? It's the big 800W 10" sub, and I need the sealed recommended size. I can't find it anywhere!
Old Mar 17, 2003 | 05:35 PM
vteg's Avatar
New User
Default Re: Volfenhag subs... (LudeyKrus)
Millionbuy has the t/s. How do you want it to sound, and how much space do you have? Someone might be able to model some boxes for you. I will if I have some time later.
800 WATTS MAX POWER
FS: 32Hz
Qts: 0.462
Qes: 0.543
Qms: 7.621
Vas: 35 L
Xmax: 16mm
Sd(piston surface area) 0.0346
Efficiency(1w/1m) 88.62dB
Dual 4 Ohm
400 Watts RMS
Mounting Depth: 145mm
Mounting hole diameter: 246mm
Old Mar 17, 2003 | 05:37 PM
LudeyKrus's Avatar
Default Re: Volfenhag subs... (vteg)
More for sq, hence the sealed box. I'm makin a simple sealed box for a friend b/c he had two of them in a ported box and blew one, so he's puttin the workin one in a sealed box. Just wanting to know how much volume these babies need.
Also, anyone else had any experience w/ these subs? I can get them cheap, and they look nice!
Old Mar 17, 2003 | 10:56 PM
philly-O's Avatar
i just had a customer bring me a set of them for me to put in his car a few months ago and the directions for recomended box volume were a small sealed or large vented box, IMO not too much help. but they sounded ok when it was all done, i used 1 cubic foot per sub sealed.
Old Mar 18, 2003 | 01:14 AM
ATF Kuk's Avatar
i believe theyre a generic brand
Old Mar 18, 2003 | 11:01 PM
vteg's Avatar
New User
0.921 cube after displacement from winisd. A prefab 1 cube box would be an easy solution for this sub. f3 at 44.
cliffsta
Audio / Security / Video
Mar 5, 2007 03:04 PM
tankdogg08
Feb 9, 2005 08:23 PM
GroundZer0 336
Jan 4, 2004 01:44 PM
slowestcivicever
Jul 18, 2002 05:49 AM
97GSR
11
Jul 7, 2001 09:36 PM
