viper 790 problem!
Old Mar 18, 2003 | 10:04 PM
doughboy247's Avatar
Default viper 790 problem!
i just had the alarm installed into a 97 CRV and the lock/unlock would only work sometime??? there's a solid connection of the green/blue wires. everything is soldered in. i can manually lock/unlock the car, but not with the alarm??? can anyone help??? i'm stumped!
btw. i'm getting a good signal from the alarm whenever the lock/unlock is activated. would i have to wire in 2 relays?
[Modified by doughboy247, 11:06 PM 3/18/2003]
Old Mar 18, 2003 | 10:13 PM
audioroach's Avatar
Default Re: viper 790 problem! (doughboy247)
If memory serves me well that car requires a strong ground trigger to lock and unlock the doors...so yes you need to add relays or a 451m pack.
Old Mar 19, 2003 | 05:27 AM
Default Re: viper 790 problem! (audioroach)
thanks for the reply audioroach. you're correct, the crv needs negative inputs for the doors to lock/unlock. could you tell me what the 451m pack is or how to wire up the relays? by adding in the relays, wouldn't that cause it to send voltage instead of a strong ground? also, why would it only work at certain times?
Old Mar 19, 2003 | 07:38 PM
TurboBumblBee's Avatar
i would definatly install a 451m relay pack to the install.. its pretty easy to install and doesnt take much.. you unplug the green and blue harness from the brain of the 790 or simply splice into green and blue wires from the 790 but then you will need to wire a 12volt power wire for the 451m.. best thing to do is plug it in.. you will need to ground the purple wires coming off the 451 to a solid ground.. then you will need to wire the green/black to the lock and blue/black to unlock, leave the white and brown wires alone, they can be taped off cause they are not needed.. easy install... and you should have power door locks that work correct.y.
Old Mar 20, 2003 | 10:08 AM
STSProtege's Avatar
Default Re: viper 790 problem! (Hybrid95CivicEX)
shame on that installer! the early CRVs are required to be used with relays. Yes, they still do work without, but as you found out, intermittently.
as suggested a 451M module or just 2 relays will get you back to normal.
Old Mar 20, 2003 | 03:21 PM
Default Re: viper 790 problem! (STSProtege)
thanks fellas! where can i get one of those 451m packs? and how much does it cost?
Old Mar 20, 2003 | 04:13 PM
92f22a1's Avatar
ebay has them for about 5.99+shipping i just bought 2 of them for 20.00 bucks shipped
Old Mar 20, 2003 | 06:22 PM
Default Re: viper 790 problem! (93lx)
how does a 451 pack work compared to 2 relays? also would i need 2 451 packs?
[Modified by doughboy247, 7:24 PM 3/20/2003]
Old Mar 20, 2003 | 07:24 PM
philly-O's Avatar
the 451m is 2 mini relays prewired for locks that plugs directly into the dei brain. very simple to install! goodluck
Old Mar 20, 2003 | 08:57 PM
rjr162's Avatar
Default Re: viper 790 problem! (peichie)
easy to use.
big purple wire to ground, big blue to car's unlock, big green to car's lock, small green to alarm unit's lock output (green), small blue to alarm unit's unlock output (blue), and red to +12V
Old Mar 23, 2003 | 08:41 AM
Default Re: viper 790 problem! (rjr162)
i went to circuit city and bought the 451m relay and at the same time i asked one of the tech's if i needed one of these relays for my crv, and he said NO? he looked it up and it did say that NO relay was needed for a crv? could the book and the tech be wrong? i still have the relay but i can return ir if i do not need it. could anyone explain why the alarm only works at certain times? usually all day and not in the mornings....
i'll install it this afternoon and see if it changes anything...it doesn't hurt to try.
[Modified by doughboy247, 9:44 AM 3/23/2003]
Old Mar 23, 2003 | 01:19 PM
rjr162's Avatar
sometimes, like for toyota's, you don't really need them, but the alarm brain doesn't give a good enough ground to control the door locks properly. Using the DEI 451M, you can give them a direct path to ground making it alot stronger
Old Mar 23, 2003 | 04:42 PM
thanks rjr162! i'll give it a try...hopefully everything goes as plan and work like it should.
byronl
Audio / Security / Video
12
Mar 27, 2008 01:51 PM
ug1yu
Jan 14, 2008 06:18 AM
WildChild
Dec 5, 2005 12:45 PM
Average DA9
Aug 17, 2004 07:27 PM
antiJDM
Jul 6, 2004 05:33 PM
