Valet/led question
Old Apr 18, 2007 | 09:51 AM
crxnj's Avatar
Default Valet/led question
This alarm I bought came with a pod that has the valet switch and status led as one..So kind of weird,I mean you're supposed to hide the valet switch but keep the led visible..Can i put some kind of switch on the valet wires to make it on/off? or not? or do i have to cut the wire and add on a new valet switch,if so can i just use a regular switch from radioshack?
Old Apr 18, 2007 | 11:20 AM
fcm's Avatar
fcm
Old Fart
Default Re: Valet/led question (crxnj)
It will be a "coded" switch, you will have to program your own code into the unit. 94
Old Apr 18, 2007 | 04:54 PM
JSPECSIR's Avatar
what kind of alarm is it? yes you should be able to cut the switch wires loose and put a mom. switch in a hidden location on those wires.
Old Apr 19, 2007 | 06:03 AM
crxnj's Avatar
Default Re: Valet/led question (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">It will be a "coded" switch, you will have to program your own code into the unit. 94</TD></TR></TABLE>
Yeah, I was reading that in the manual about how you could program your own sequence for the button,but I just don't like it in the open like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">what kind of alarm is it? yes you should be able to cut the switch wires loose and put a mom. switch in a hidden location on those wires.</TD></TR></TABLE>
So I can just install any toggle switch in between the wires and have it on/off? the toggle switch won't be acting like a new valet button or anything right?
it's a newer crimestopper "CS-2002DC series IV"
Here's a pic of my valet/led for reference.
Old Apr 19, 2007 | 03:03 PM
JSPECSIR's Avatar
oh i see what your saying. a toggle switch to de activate the valet switch. yes that would work. just cut one wire and put your switch between the cut section.
Old Apr 19, 2007 | 04:01 PM
crxnj's Avatar
Default Re: Valet/led question (JSPECSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote">oh i see what your saying. a toggle switch to de activate the valet switch. yes that would work. just cut one wire and put your switch between the cut section.</TD></TR></TABLE>
Will this single post single throw toggle switch from radioshack work? http://www.radioshack.com/prod...earch
Old Apr 19, 2007 | 04:17 PM
fcm's Avatar
fcm
Old Fart
It will not, you will need a momentary switch, either a toggle or push button.
Can you not remove the LED and button from the housing and just mount them where you want? 94
Old Apr 19, 2007 | 04:24 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> It will not, you will need a momentary switch, either a toggle or push button.
Can you not remove the LED and button from the housing and just mount them where you want? 94</TD></TR></TABLE>
How about this onehttp://www.radioshack.com/prod...earch
I tried to seperate the 2 but honestly I don't want to risk breaking anything.And on the back there is some rubberized coat that has the wires attatched.
Old Apr 20, 2007 | 06:22 PM
fcm's Avatar
fcm
Old Fart
Yes it will. 94
hatchaholic
Audio / Security / Video
Sep 2, 2014 03:37 PM
curtie94
Apr 8, 2011 05:23 PM
maxheat
Feb 21, 2007 02:10 PM
pwrofdrm
Aug 21, 2004 05:42 PM
MileHigh
Sep 27, 2003 06:13 PM
