using headlights as strobes
Old Jan 11, 2004 | 10:02 AM
dvela85's Avatar
Default using headlights as strobes
has anyone ever connect there headlights for strobes? anyone know how to connect the parking lights and the low beam and high beam to the alarm, so when its tripped all the lights will go off and have a strobe look to it
Old Jan 11, 2004 | 12:36 PM
vteg's Avatar
New User
Default Re: using headlights as strobes (dvela85)
I would just buy a strobe and tap into the corners(clears will help here definately). The headlight don't illuminate fast enough to even resemble a strobe. Luckily there are many ricers. So strobes are cheap
Old Jan 11, 2004 | 01:36 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvela85 &raquo;</TD></TR><TR><TD CLASS="quote">has anyone ever connect there headlights for strobes? anyone know how to connect the parking lights and the low beam and high beam to the alarm, so when its tripped all the lights will go off and have a strobe look to it</TD></TR></TABLE>
i dont think you can use can use normal halogen lights for strobes. They're not fast enough.
Old Jan 11, 2004 | 04:21 PM
dvela85's Avatar
Default Re: using headlights as strobes (EBP_SI)
well its for security reasons
Old Jan 11, 2004 | 04:24 PM
EBP_SI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvela85 &raquo;</TD></TR><TR><TD CLASS="quote">well its for security reasons</TD></TR></TABLE>
that still doesn't change the fact that halogens are not fast enough for strobes.
Old Jan 11, 2004 | 07:30 PM
B18C_EJ8's Avatar
You could get a wig-wag relay system, and have the headlights alternate, like on a police car... Or just get some strobes, and have them activated by an output off your alarm...
Old Jan 11, 2004 | 10:23 PM
hybridzOr's Avatar
Default Re: (B18C_EJ8)
hmmm, usually when my system hits hard the head lights dim, does that count as a strobe?
Old Jan 11, 2004 | 11:33 PM
vteg's Avatar
New User
Default Re: (HybridRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridRacer &raquo;</TD></TR><TR><TD CLASS="quote">hmmm, usually when my system hits hard the head lights dim, does that count as a strobe? </TD></TR></TABLE>
Haha.
To the original poster. Drill a hole and insert these
You could connect them to an alarm output, or use the siren output to trigger a relay to give them power.
Old Jan 11, 2004 | 11:49 PM
ojrapedmyfather
Guest
Posts: n/a
Old Jan 12, 2004 | 04:39 AM
dvela85's Avatar
where can i get this wig-wag relay system
Old Jan 13, 2004 | 04:05 PM
B18C_EJ8's Avatar
http://www.galls.com/style.htm...FS039
Old Jan 13, 2004 | 07:15 PM
HiRevn's Avatar
Default Re: (ojrapedmyfather)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ojrapedmyfather &raquo;</TD></TR><TR><TD CLASS="quote">******????!!@#!@#</TD></TR></TABLE>
LOL That's what I thought they were at first
Old Jan 14, 2004 | 09:13 AM
TiggsCRX's Avatar
wig wags are cool. i have a set in my rex. might consider letting em go since I never use em though. looks confusing to hook up, but they really arent. has multiple patterns to choose from too. much better than using those stupid cheap apc strobe kits that blink at the rate of like 45 flashes per minute randomly.
Old Jan 14, 2004 | 12:08 PM
dvela85's Avatar
Default Re: (TiggsCRX)
do u have them connected to your alarm
Old Jan 14, 2004 | 12:14 PM
itsJDMyo's Avatar
Default Re: (dvela85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvela85 &raquo;</TD></TR><TR><TD CLASS="quote">do u have them connected to your alarm</TD></TR></TABLE>
that sounds like a good idea, i might try that
Old Jan 15, 2004 | 07:24 AM
ASHY-ELBOW's Avatar
Default Re: (b00st)
http://www.911lighting.com/flashers
they are cheap and do cod also
Old Jan 15, 2004 | 08:57 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (ASHY-ELBOW)
I believe this is the first time I ever posted in this forum....oh well.
Try http://www.radartest.com There is a link in there for something called SunDance. That's the system cops use to alternate their high beams back and forth. It's pretty cheap from there and you can pretty much put it on any car. Even comes with an optional kit to install it.
Whoever posted those little "*****" strobes, I hope you know those strobes will barely light up anything. Those are those APC-ish $20 lights that you buy from Pep Boys and such. Sure, if that's what you want, then go ahead.
But if you want what you see at shows, you'll have to get the real system. Those are pretty pricey, at about $400+. You need the control module, as well as the bulbs. The bulbs aren't cheap either. I haven't looked into them in a LONG LONG time, but depending on how many lights you want, that's the number of "contacts" your module must have. For example an 4 bulb module will not cost as much as a 6 or 8 bulb module. However, it can only light 4 bulbs at a time, and that's it.
Call me a ricer, but I always thought real police strobes were kinda cool.
Old Jan 15, 2004 | 09:39 PM
vteg's Avatar
New User
Default Re: (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">
Call me a ricer, but I always thought real police strobes were kinda cool. </TD></TR></TABLE>
Thanks for the info. Being the anti-rice I did not know that.
gotmilk
Honda Accord (2013 - 2015)
Jan 4, 2018 09:09 AM
GoFastOrGoShlow_HNDA4LIF
12
Apr 24, 2007 10:44 AM
Jaypee
Feb 16, 2005 12:50 PM
speedycivicgurl
Aug 13, 2004 07:21 PM
dip-set
Dec 30, 2002 10:06 PM
