Two amps to one sub.
NO, Never mix amps of different wattage on the same sub. If you wanted to bi-amp a sub(usually must be a DVC) you should use two of the same amps and would be wise to set it up with an O-scope.
oh. i have another question, is it possible to use a mono amp for my mids? its supose to be for a sub cause it has lpf's on it but i can turn it off.
why? will it sound like a sub? wont go as high? my mids have crossovers on them so i can put them on the high output and plus i have tweeters so u think it will even out?
It will sound wierd because it will be mono, you are used to listen to music in stereo. That is the only reason. As long as the LPF can be disabled then you are good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auex »</TD></TR><TR><TD CLASS="quote">It will sound wierd because it will be mono, you are used to listen to music in stereo. That is the only reason. As long as the LPF can be disabled then you are good.</TD></TR></TABLE>
and chances are if its a mono amp its a class D. very limited frequency range even without the LPF and generally have a high THD when compared to the class a/b's
JohnnyEF
Audio / Security / Video
Nov 26, 2006 12:04 PM
SSBP DC2
Apr 18, 2003 12:22 AM
